2 Replies Latest reply on Aug 27, 2007 6:28 AM by tedalde2
    how to get file name on the base of extension
    farhanakhan Level 1
      hi
      reply me
      how to get the filename on the base of extension from the current directory......
      for example
      i create file with the "igg" extension and save in the folder where the exe file of director save....
      i want when exe run then exe file read filename of the define( "igg" ) extension with out path just name of the file with igg extension
      tel me how
      regards
      farhana khan
        • 1. how to get file name on the base of extension
          James Newton, ACP Level 3
          Here's a solution that requires no xtras:
          on GetFilesWithExtension(aFolderPath, aExtension) --------------------
          -- INPUT: <aFolderPath> should be a valid string folder path
          -- <aExtension> may be a string file extension, without the
          -- dot. For example: "txt" or "igg"
          -- OUTPUT: Returns an error symbol or a linear list of file names
          -- in the given folder. If an extension is given, only
          -- files with the given extension will be listed. If not,
          -- all files and folders will be listed.
          vFileList = []
          if not stringP(aFolderPath) then
          return #stringPathExpected
          end if
          vIgnoreExtension = not stringP(aExtension)
          vDelimiter = the itemDelimiter
          the itemDelimiter = "."
          n = 0
          repeat while TRUE
          n = n + 1
          vFileName = getNthFileNameInFolder(aFolderPath, n)
          if vFileName = "" then
          exit repeat
          end if
          if vIgnoreExtension then
          vFileList.append(vFileName)
          else if the last item of vFileName = aExtension then
          end if
          end repeat
          the itemDelimiter = vDelimiter
          return vFileList
          end GetFilesWithExtension
          You can also use Buddy API's baFileList, which allows you to do wildcard searching.
