4 Replies Latest reply on Apr 11, 2010 1:19 PM by EMelville
    XML Woes. Using XMLCollections, minor issue.
    EMelville Level 1
      Been pulling my hair out trying to get this little resultevent function to work:
      Neither this one:
      private function getXMLResult(evt:ResultEvent):void {
           AmbientXMLCollection = GetXmlService.lastResult.image as XMLListCollection;
           testtxt.text = AmbientXMLCollection.toString();
      or this one:
          AmbientXMLCollection = new XMLListCollection(GetXmlService.lastResult.image);
      Produces any effect. Except for an [object Object] in a textbox.
      The XML:
      <gallery>
      <image username="agoodname"/>
      </gallery>
      The Service:
      <mx:HTTPService id="GetXmlService"
                  url="include/gallery.xml"
                  fault="getXMLFault(event);"
                  result="getXMLResult(event);"
                  showBusyCursor="true" />
      The bottom line:
      Simply trying to get the xml "in full" to display in a text box. Can anyone help?
        • 1. Re: XML Woes. Using XMLCollections, minor issue.
          Radhakrishna Bhat Level 3
          If only XML String representation in textbox is required, inside getXMLresult function event.result is already an XML (if you set HTTPService's property resultFormat to e4x). Then use event.result.toXMLString()
          -Radhakrishna
          • 2. Re: XML Woes. Using XMLCollections, minor issue.
            EMelville Level 1
            Ok, perfect.
            Now I have:
            <mx:TileList id="tileList"
            dataProvider="{AmbientXMLCollection}"
            itemRenderer="CustomItemRenderer"
            columnCount="4"
            columnWidth="125"
            rowCount="2"
            rowHeight="150"
            verticalScrollPolicy="on"
            itemClick="tileList_itemClick(event);"  x="514" y="40"/>
            Any reason why the xml data won't populate in the tile list?
            Thanks Radhakrishna.
            • 3. Re: XML Woes. Using XMLCollections, minor issue.
              EMelville Level 1
              Even tried this.
                   tileList.dataProvider = AmbientXMLCollection;
              Still nothing in the TileList yet. I must be missing something simple like the e4x in the httpservice.
              MXML:
              resultFormat="e4x"
              columnCount="4"
              columnWidth="125"
              rowCount="2"
              rowHeight="150"
              • 4. Re: XML Woes. Using XMLCollections, minor issue.
                EMelville Level 1
                I got it. Binding to dataProvider="{GetXmlService.lastResult.image}" did it.
