11 Replies Latest reply on Apr 12, 2010 12:30 PM by the_wine_snob
    Dip To Black jitter
    PnoT00
      I've imported a video from my MotionPro HD camera which is 720P and set the project up accordingly.  My issue is whenever i put a dip to black it jitters, or studders, when going to and from black.  I've tried several things to alleviate the problem but no such luck.  I have seen posts where the bitrate was too low to accomplish the dip but my source video is 15mbs so that seems to be way above what others had.  I have tried to change the dip length as well with no luck.
      *Edit*
      Dip to black works flawless if i cut a video and insert the transition but if i have 2 different video segments that are in different spots in my timeline and put them together with a dip to black between them it fails and jitters.  I hope I'm explaining this properly.
        • 1. Re: Dip To Black jitter
          Jeff Bellune Level 5
          Welcome to the forum!
          Version of Premiere Pro, please?
          Most likely your issue is addressed here:
          http://help.adobe.com/en_US/PremierePro/4.0/WS17A423FB-FEF8-4172-A7C8-8521D8CCB8C8.html
          If not, or if you have more questions, please post back.
          -Jeff
          • 2. Re: Dip To Black jitter
            PnoT00 Level 1
            I'm using CS4 with the latest updates available.  I looked the link you provided and I don't see any of the zig zag patterns like that.
            • 3. Re: Dip To Black jitter
              the_wine_snob Level 9
              Do you have adequate Handles on your Clips? If not, you will have issues. Because of this line:
              This will give you some background on Handles:
              PS - also, is there a red line above the Clips and Transitions? If so, does it look better, when you press Enter, to Render?
              • 4. Re: Dip To Black jitter
                PnoT00 Level 1
                I'm not really sure how to look for this in my video but i never get a warning saying that frames are being repeated.
                I always render the effects before previewing it.
                • 5. Re: Dip To Black jitter
                  OK, what CODEC is used by the MotionPro? Could be a GOP issue, and when you are Trimming the Clips, you are having issues.
                  What is your Project/Sequence setting?
                  • 6. Re: Dip To Black jitter
                    PnoT00 Level 1
                    Video
                    Format                           : AVC
                    Format/Info                      : Advanced Video Codec
                    Format profile                   : Main@L4.0
                    Format settings, CABAC           : Yes
                    Format settings, ReFrames        : 4 frames
                    Frame mode                       : Frame doubling
                    Codec ID                         : avc1
                    Codec ID/Info                    : Advanced Video Coding
                    Duration                         : 13mn 15s
                    Bit rate mode                    : Variable
                    Bit rate                         : 15.0 Mbps
                    Width                            : 1 280 pixels
                    Height                           : 720 pixels
                    Display aspect ratio             : 16:9
                    Frame rate mode                  : Variable
                    Frame rate                       : 59.940 fps
                    Minimum frame rate               : 59.920 fps
                    Maximum frame rate               : 59.960 fps
                    Original frame rate              : 29.970 fps
                    Resolution                       : 8 bits
                    Colorimetry                      : 4:2:0
                    Scan type                        : Progressive
                    Bits/(Pixel*Frame)               : 0.271
                    Stream size                      : 1.39 GiB (99%)
                    Title                            : Ambarella AVC
                    Language                         : English
                    Encoded date                     : UTC 2010-04-04 11:18:00
                    Tagged date                      : UTC 2010-04-04 11:18:00
                    Audio
                    Format                           : AAC
                    Format/Info                      : Advanced Audio Codec
                    Format version                   : Version 4
                    Format profile                   : LC
                    Format settings, SBR             : No
                    Codec ID                         : 40
                    Duration                         : 13mn 15s
                    Bit rate mode                    : Constant
                    Bit rate                         : 128 Kbps
                    Channel(s)                       : 2 channels
                    Channel positions                : Front: L R
                    Sampling rate                    : 48.0 KHz
                    Stream size                      : 12.1 MiB (1%)
                    Title                            : Ambarella AAC
                    Language                         : English
                    Editing Mode: MainConcept AVCHD
                    Timebase: 59.94
                    Display format: 60fps Non-Drop-Frame Timecode
                    • 7. Re: Dip To Black jitter
                      PnoT00 Level 1
                      I played around with this for about 4 hours yesterday and still nothing.  Any tips fellas?
                      • 8. Re: Dip To Black jitter
                        PnoT00 Level 1
                        I figured coming to the forums would provide some feedback that would lead to a resolution but that didn't happen.  I tinkered around with the problem for a long while and found solution that "works" but isn't optimal.
                        Instead of inserting a dip to black inbetween 2 cuts i spaced the cuts out 1 second apart and applied a 1s dip to black on the end of the first cut and the beginning of the 2nd cut.  The studder/jitter is gone and the net result is 3 seconds of fade which i was shooting for to begin with.
                        Since i replaced the entire audio track things came out pretty smooth.
                        I still don't understand why this happens and I can't believe there are not more users that have ran across this problem.
                        • 9. Re: Dip To Black jitter
                          I strongly recommend that you add Black Video to that gap, as they can cause all sorts of issues, especially with Export/Transcode. You can create your Black Video, and then set its Duration down to the Frame-level.
                          • 10. Re: Dip To Black jitter
                            PnoT00 Level 1
                            I wound up pulling the gap closed but keeping the 2 seperate dip to black transitions and it's working beautifully.
                            • 11. Re: Dip To Black jitter
                              Great news! Thanks for reporting. I just did not want you to start getting "Failure to Return Frame," or other Transcoding errors, when you go to Export.
