16 Replies Latest reply on Apr 15, 2010 7:38 AM by Steve Grisetti
    PE7 crashes when I add a video elements?
    simonneal72
      I have PE 7 running on a dell desktop
      that has been upgraded to windows 7.
      Its a new computer and PE7 wasn't run when under vista.
      When you load PE7 it will start but if you add a video file it crashes.
      Then everytime you re load PE7 it crashes as soon as you either start
      a new project or exisiting. If you rename the video file PE7 can't find it and
      so loads. I can add photo elements no problem.
      I tried reinstalling didn't help.
      All drivers are up to date.
      Video files are .mpg
      Tried creating anew users same problem
      Any clues anyone?
        • 1. Re: PE7 crashes when I add a video elements?
          the_wine_snob Level 9
          Welcome to the forum.
          Take a look at this ARTICLE, to get an idea of the additional info that will be very useful to us.
          Also, when you say that you "upgraded to Win7," did you do a clean install, or just upgrade from Vista? Is Win7 32-bit, or 64-bit?
          • 2. Re: PE7 crashes when I add a video elements?
            Also, what kind of camcorder is your video coming from and how did you get it into your computer?
            • 3. Re: PE7 crashes when I add a video elements?
              simonneal72 Level 1
              Thanks I will read through the article and post
              the relevant info.
              It was an upgrade from Vista Home premium 64 bit
              • 4. Re: PE7 crashes when I add a video elements?
                simonneal72 Level 1
                It was from a sony camcorder (need
                to get specs) and was downloaded using the windows
                default downloader.
                • 5. Re: PE7 crashes when I add a video elements?
                  There have been quite a few reports of upgrading from Vista to Win7 causing issues. I hope that will not be part of the problem. I have always found that a clean OS install worked far better for me.
                  Good luck, and we'll be looking for the details.
                  • 6. Re: PE7 crashes when I add a video elements?
                    We'll be able to tell more once we find out if your camcoder is a hard drive, miniDV, HDV or AVCHD hard drive camcorder.
                    • 7. Re: PE7 crashes when I add a video elements?
                      simonneal72 Level 1
                      Its a harddrive camcorder
                      • 8. Re: PE7 crashes when I add a video elements?
                        Again, Simon, that doesn't tell us anything. There are several types.
                        Can you post the model number from the bottom of the cam? We can look it up for you.
                        • 9. Re: PE7 crashes when I add a video elements?
                          simonneal72 Level 1
                          Yeah sorry I'm not at home at the moment so can't get the details. Will do a soon as I am back.
                          Cheers
                          Simon
                          • 10. Re: PE7 crashes when I add a video elements?
                            simonneal72 Level 1
                            Okay so here are the details of the Desktop
                            Studio Desktop 540MT : Intel Core 2 Quad-Core Q9400 (2.66GHz,1333MHz,6MB)
                            Memory : 8192MB (4x2048) 800MHz DDR2 Dual Channel
                            Hard Drive : 1TB Serial ATA (7200RPM)
                            Graphics : 1024 MB nVidia GeForce GT220
                            Audio Integrated HDA Dolby Digital capability
                            And the camcorder is a :
                            Sony Handycam 30Gb DCR-SR42
                            • 11. Re: PE7 crashes when I add a video elements?
                              Your camcorder is a standard definition hard drive camcorder.
                              You should use DVD/Hard Drive Camcorder project preset and you should use Get Media/from Hard Drive Camcorders to download the files from the camcorder into your computer.
                              You will also need to render your files regularly as you add them to your timeline so that the red line above the clips is green as much as possible.
                              • 12. Re: PE7 crashes when I add a video elements?
                                simonneal72 Level 1
                                thanks steve, i tried a project using your recommended preset and still have the same issue. I will post further details as i am finding them
                                • 13. Re: PE7 crashes when I add a video elements?
                                  simonneal72 Level 1
                                  Okay so I have more details that may help.
                                  I can add .mov, .m4v and .wmv files with no problems
                                  I can add audio files also.
                                  When PE7 crashes when you add a .mpg is gives the following details
                                  Problem signature:
                                  Problem Event Name: BEX
                                  Application Name: Adobe Premiere Elements.exe
                                  Application Version: 7.0.1.0
                                  Application Timestamp: 494ac29e
                                  Fault Module Name: MSVCR80.dll
                                  Fault Module Version: 8.0.50727.4927
                                  Fault Module Timestamp: 4a2752ff
                                  Exception Offset: 00008aa0
                                  Exception Code: c000000d
                                  Exception Data: 00000000
                                  OS Version: 6.1.7600.2.0.0.768.3
                                  Locale ID: 2057
                                  Additional Information 1: fe84
                                  Additional Information 2: fe84be54ae644be0970e6312dba81545
                                  Additional Information 3: 0b5f
                                  Additional Information 4: 0b5fb15b07518661054544c6551ca23e
                                  Also if I reload a prject once i have renamed the video file and then I try and update the missing file
                                  you first get a Runtime error
                                  With details R6025 - Pure virtual function call - Runtime Error
                                  And then a crash with the following details
                                  Problem signature:
                                  Problem Event Name: APPCRASH
                                  Fault Module Name: MediaLayer.dll
                                  Fault Module Version: 7.0.1.0
                                  Fault Module Timestamp: 494ab2e7
                                  Exception Code: 40000015
                                  Exception Offset: 0018c367
                                  Locale ID: 2057
                                  Additional Information 1: 0273
                                  Additional Information 2: 027333e70af5c707ec71dc376ff3e0b6
                                  Additional Information 3: 00f4
                                  Additional Information 4: 00f41fb4ce75e1ce26c10ef87e21954
                                  • 14. Re: PE7 crashes when I add a video elements?
                                    You've updated your system, defragged your drive and you're using a standard video format.
                                    At this point, I'm not sure we can be much more help for you on the forum. You likely need more specific troubleshooting, including possibly a check for a program conflict.
                                    You can certainly use MPEG Streamclip to convert those MPEGs into DV-AVIs, and those should work perfectly in a project set up with the DV presets.
                                    http://forums.adobe.com/thread/415317?tstart=0
                                    But there may also be something deeper going on with your system. You certainly should not be having problems with such basic footage.
                                    A call to Adobe Tech Support may be in order. Sorry that I can't do more for you.
                                    • 15. Re: PE7 crashes when I add a video elements?
                                      simonneal72 Level 1
                                      Hi Steve,
                                      Yeah thanks for that, I put a call into support and they want to charge me £25 for the call but recommended upgrading to PE 8 as they know that it
                                      has been tested with Windows 7 (even though the website says PE7 is compatible!) and we would get free support with that. I need it to be a stable as possible because its my father computer and he is wanting to do some video editing and wouldn't be able to troubleshoot like this and i live in Uganda. So I think we will go for the upgrade.
                                      Would you recommend any easy guides to video editing I could look at for him?
                                      Thanks for all your help.
                                      • 16. Re: PE7 crashes when I add a video elements?
                                        I absolutely would recommend that you NOT upgrade to version 8, Simon, if you want more stability!
                                        Version 7 is much more stable a product -- and, in my opinion, if youre having problems with version 7, version 8 is going to definitely give you a world of heartache.
                                        As for books on Premiere Elements -- Hey, you're talking to the source! I've written a number of books on various versions of Premiere Elements and the Photoshop Elements/Premiere Elements bundle as well as my latest book on creating special effects with Premiere Elements. You can find them all on Amazon or at the Muvipix.com store. If you're not able to order these books from your country, then just drop me a line at steve at muvipix dot com and I'll gladly arrange for them to drop-shipped.
                                        Meantime, be sure to check out my site http://Muvipix.com. Not only will you find the most knowledgeable, helpful community forum on the web there, but there are dozens of free tips, tutorials, media clips, music clips and custom created DVD menus available on the site, and over 1000 pieces available if you order a subscription to the site.
                                        And certainly have a look at my free Basic Training with Premiere Elements tutorials. They're a great way to get up and running with this program.
