Premiere Pro CS4 (Windows 7) will not (Capture or Record) connect with DV Cass Recorder
tennischocolate88 Apr 11, 2010 8:28 PMFor 12 yrs I've Never had a problem w Adobe Prem Pro seeing my Panasonic AG-DV2000, DV cassette Recorder. Premiere Pro CS4 (with Windows 7 Ultimate) will not connect (Capture or Record)with my DV Cassette Recorder - Panasonic AG-DV2000. I upgraded my computer to below components & added Windows 7 at same time. Have had Adobe Prem Pro CS4 since fall with no problems. I usually have 2 - 5 videos, with 2 - 4 audios, going at same time on my timeline. (These digital videos & audios I shot myself professionally with mini DV cassettes.) Most projects are between 10 to 50 mins on timeline, w transitions or crossfades between video & audios. Firewire attached from computer to Panasonic. No Capture card in new system, not needed, use to watch over an external TV, now watch over a second monitor or in program monitor. [Am I just missing a simple setting??] Computer below & settings: very up to date.
motherboard ASUS P6T
CPU i 7 2.67 GHz
RAM 6 GB
video ATI Radion HD 5700 1 gig Memory OpenGL 3.2
Main Drive 500g SATA 7200 rpm
Raid Drive 1.2 TB 7200 SATA
Windows 7 64 Bit Ultimate
DVD/CD writable Disc Drive
AVG Antivirus 9.0
Playback Settings
Realtime Playback
yes Desktop Video Display
External Device DV 25 720X 576i
Aspect Ratio Conv Hardware
yes External Device Audio
Export External Device DV 25 720X 576i
yes Disable Video output when in background.
24p Conversion Method - Interlaced frame 2:3:3:2
Preferences (only things not set at default)
Audio Output Mapping -- Premiere Pro WDM Sound (have also tried Audio Out)
Device Control DV/HDV Device Cont Options: NTSC, Panasonic, AG-DV2000P, Auto Detect
(Check Status) Says it is ONLINE
Media Cache files saved to My Raid drive not C drive (so they will run faster)
Indeterminate Media Timebase: 29.97 fps Non Drop Frame
Project Settings Video -- Timecode Audio -- Audio Samples
Capture Format (tried both) DV & HDV (all settings checked for during preview & capture)
Under DV says Panasonic is Online, export to tape/it renders/Premiere controls the Panasonic recorder -looks like it's recording, but see no video - hear the sound. On Playback nothing was recorded? ( And Can't capture from tape to computer)
Under HDV Says Panasonic is Offline, but computer able to control the Panasonic start/stop, but doesn't record or capture tape to computer?
[ I think this DV/HDV part is correct...... it's getting very confusing at this point??!! Your help is appreciated Thank YOU ]
