1 2 3 Previous Next 92 Replies Latest reply on Nov 27, 2016 12:39 AM by Laubender Branched to a new discussion.
    With CS5, some things have changed
    Harbs. Level 6
      This discussion is for changes to the scripting DOM which can affect legacy scripts.
      Please use this discussion for discussing new scripting features in CS5.
      Please keep in mind that all changes are specific to version 7 DOM. InDesign supports versioning, so you should be able to use legacy scripts in CS5 without issues. Versioning can be done in two ways:
      1) Place the script in a folder named: "Version 6.0 Scripts" (or 5.0, 4.0, 3.0). The folder must be named exactly as specified.
      2) Set the script version preferences at the start of your script. (i.e. app.scriptPreferences.version = 6), but it's highly recommended to reset the scripting version at the end of the script, and even to enclose the script in a try/catch/finally block to ensure that the script preferences are reset correctly.
      Here's quick links to issues brought up in this thread:
      1. PageItem.parent
      2. PageItem.itemByName()
      3. PageItem.cornerOption and PageItem.cornerRadius
      4. Text values returned as Strings instead of Numbers
      5. PointType.LINE_TYPE was changed to PointType.PLAIN
      6. PasteBoardPreference.minimumSpaceAboveAndBelow was removed.
      Harbs
        • 1. Re: With CS5, some things have changed
          Harbs. Level 6
          Here's the first two (and probably the most significant) of the changes:
          1) PageItem.parent: In previous versions, the parent of top-level page items were the Page that the PaeItem resided on. In CS5, this was changed (for increased performance), and the parent is now the PageItem's Spread. Together with this change, a new property "PageItem.parentPage" was added which returns the page that the PageItem is drawn on. parentPage works for nested PageItems as well, so this new property will do away with the need for a lot of the "findPage" functions that we've all been using!
          2) PageItems.itemByName(): With the new layers panel comes a name property for PageItems. In previous versions PageItems.itemByName() would return the page item with the specified label in CS5, it will return the page item with the specified name (which can be set in the Layers Panel). There is no longer a quick-and-easy way to get page items by their label using the 7.0 scripting DOM.
          Harbs
          • 2. Re: With CS5, some things have changed
            Harbs. Level 6
            PageItem.cornerOption and PageItem.cornerRadius is gone.
            Instead there's now: bottomLeftCornerOption, bottomRightCornerOption, topLeftCornerOption, and topRightCornerOption. The same for cornerRadius. This is to support the new live corner features.
            Harbs
            • 3. Re: With CS5, some things have changed
              SuperMacGuy Level 2
              Does this affect only JS scripts, or all scripting? I do Applescripting and we have A LOT of workflow that depends on item labels. Will this change for Applescripting?
              Chris
              • 4. Re: With CS5, some things have changed
                Dave Saunders Level 4
                I'm not so sure that the .parentPage property does away with the need for findPage. I was just working on it right now and came to the conclusion that for a general function, it just changes it a bit:
                function findPage(theObj) {
                     if (theObj.hasOwnProperty("baseline")) {
                          theObj = theObj.parentTextFrames[0];
                     while (theObj != null) {
                          if (theObj.hasOwnProperty ("parentPage")) return theObj.parentPage;
                          var whatIsIt = theObj.constructor;
                          switch (whatIsIt) {
                               case Page : return theObj;
                               case Character : theObj = theObj.parentTextFrames[0]; break;
                               case Footnote :; // drop through
                               case Cell : theObj = theObj.insertionPoints[0].parentTextFrames[0]; break;
                               case Note : theObj = theObj.storyOffset; break;
                               case Application : return null;
                          if (theObj == null) return null;
                          theObj = theObj.parent;
                     return theObj
                } // end findPage
                I believe that this function will work with any version of InDesign because it will behave the same as before in versions that don't support the parentPage property.
                Of course, if you know you're dealing with an object that has a parentPage property in CS5, you can just go straight for the property.
                Dave
                • 5. Re: With CS5, some things have changed
                  Chris,
                  I expect that AppleScript users can still take advantage of whose clauses to get at the label (provided they can master the syntax).
                  In JavaScript, the news is worse than I feared because you can't even use versioning to get around this. All scripts that use item("label") to get at stuff will have to be rewritten.
                  Dave
                  • 6. Re: With CS5, some things have changed
                    AdobeScripts Level 3
                    I think it won't because of this line:
                    In CS1 it's ParentTextFrame - one item - not array/collection.
                    robin
                    www.adobescripts.co.uk
                    • 7. Re: With CS5, some things have changed
                      Harbs. Level 6
                      Dave,
                      Did you try my suggestion to use blabla.item("bla").getElements()[0] with versioning to resolve the object with versioning?
                      Harbs
                      • 8. Re: With CS5, some things have changed
                        sstanleyau Level 4
                        Yes. To refer by item, you should use something like:
                        item 1 of all page items whose label is "whatever"
                        A lot of people have been using this sort of construction anyway, to deal with the possibility of grouping, so they should be largely unaffected.
                        The other thing to keep in mind is that versioning solves the problem for AppleScript.
                        Shane Stanley <sstanley@myriad-com.com.au>
                        • 9. Re: With CS5, some things have changed
                          sstanleyau Level 4
                          Dave,
                          Aren't you ignoring items on the pasteboard there?
                          • 10. Re: With CS5, some things have changed
                            Shane,
                            In the function? Yes -- by definition, they're not on a page. So, they'll return null.
                            Dave
                            • 11. Re: With CS5, some things have changed
                              Harbs,
                              I think I must be wrong about this because to my immense surprise your code works -- my surprise is caused by the certainty that that's just what I tried when I concluded it didn't work. I just did this:
                              1. I created a new document in CS5.
                              2. I dragged out a text frame and labeled it "Fred".
                              3. I duped that twice.
                              4. I ran this script:
                              var myDoc = app.documents[0];
                              var myTFs = myDoc.textFrames.item("Fred");
                              alert(myTFs == null);
                              app.scriptPreferences.version = "6.0"
                              var myTFs = myDoc.textFrames.item("Fred").getElements();
                              app.scriptPreferences.version = "7.0"
                              alert(myTFs.length);
                              There's a caveat here. The end result is an array and not a collection. But presumably the getElements() part is optional. Let me try another experiment. Aha! No it's not optional. This might well explain my confusion. This works:
                              alert(myTFs.toSource());
                              app.scriptPreferences.version = "7.0";
                              But this doesn't:
                              So, if you create an object reference while working within the CS4 versioning engine it won't work when you move back into the CS5 engine. So, by converting to an array--by using getElements()--which is a core feature, you can pass objects effectively from one engine to the other.
                              So, if you were converting your collection to an array anyway, then this makes converting the script a whole lot easier than I had feared. On the other hand, if you were using the reference as a collection, then you need to stay within the CS4 versioning engine for it to work. I wonder if you can move in and out of versions ... Yes!
                              // some code so that something happens while we're in this engine
                              for (var j = 0; myDoc.textFrames.length > j; j++) {
                                   myDoc.textFrames[j].fillColor = myDoc.swatches[-1];
                              Well, this isn't as bad as I feared, but I can see me having to add a lot of versioning statements to scripts I convert from CS4 to CS5
                              Thanks for pointing me in the right direction Harbs.
                              Dave
                              • 12. Re: With CS5, some things have changed
                                Harbs. Level 6
                                Hi Dave,
                                Glad it worked. I really would have been surprised if it didn't!
                                This is the good old referencing problem. Besides giving you and array, getElements() resolves the specifier to the object, so until you use getElements(), the specifier is equivalent to ".item()" which has a different meaning in the 7.0 DOM. After using getElements(), the specifier(s) is (are) resolved to the equivalent of ".itemByID()", which will always give you the correct object(s).
                                Harbs
                                • 13. Re: With CS5, some things have changed
                                  beh_gras_beh
                                  I am not a great scripting hero but i just have one question.
                                  I have a Indesign file wich has a bunch of pages.
                                  On each page there is a textframe wich is labelled "textcode".
                                  When i run the script, Indesign exports each page to a pdf giving the name what's in the labelled textframe.
                                  The problem is, i think, the line:
                                  f = File (myFolder + "/" + p[i].textFrames.item ('textcode').contents + ".pdf");
                                  Wich contains textFrames.item.
                                  Does anybody knows what i have to change to let it work in CS5?
                                  Already thanks for everyone who wants to help,
                                  Regards,
                                  Bert
                                  Holland
                                  Update: Sorry guys, wasn't reading good. So the problem is solved!
                                  • 14. Re: With CS5, some things have changed
                                    Harbs. Level 6
                                    FWIW,
                                    Here's a general purpose function which gives pre-CS5 behavior for getting items by label using Dave's versioning method:
                                    function GetItemFromCollection(label,collection){
                                        var scriptVersion = app.scriptPreferences.version;
                                        if( parseFloat(scriptVersion) > 6){app.scriptPreferences.version = 6}
                                        var items = collection.item(label).getElements();
                                        app.scriptPreferences.version = scriptVersion;
                                        if(items.length==0){return null}
                                        if(items.length==1){return items[0]}
                                        return items;
                                    To use it you'd do something like this:
                                    items = GetItemFromCollection("test",app.documents[0].pageItems);
                                    If you prefer prototype methods, you can use a function like this:
                                    PageItems.prototype.itemByLabel = function(label){
                                        var items = this.item(label).getElements();
                                        return items;
                                    However keep in mind that you'd need to do this for each type of collection, and you cannot create prototype functions on collections until you initialize the collection. To do that you'd need to insert a line like this (assuming there's a document open):
                                    You could then write:
                                    items = doc.pageItems.itemByLabel("test");
                                    Harbs
                                    • 15. Re: With CS5, some things have changed
                                      Harbs. Level 6
                                      Some (most) of the text properties which used to return Numbers can now return Strings. This can be a problem if you have a script which adjusts these values.
                                      For example: myText.pointSize = myText.pointSize+1.
                                      In CS4, this would take 12 point text and make it 13 points. In CS5, it'll take the same 12 point text and make it 121 points. This is becase it uses the String "+" operator rather than the Number one. This can catch you really off guard the first time it happens...
                                      The fix is to cast the String as a Number like so: myText.pointSize = Number(myText.pointSize)+1.
                                      Harbs
                                      • 16. Re: With CS5, some things have changed
                                        sudar1983_14 Level 2
                                        Footnote will allow the xml tags in CS5?
                                        Arivu..
                                        • 17. Re: With CS5, some things have changed
                                          PankChat Level 1
                                          No. I don't think so.
                                          One of the pain area for XML works in ID.
                                          sudar1983_14 <forums@adobe.com>
                                          07/03/10 02:41 PM
                                          Please respond to
                                          clearspace-721659546-639966-2-2945664@mail.forums.adobe.com
                                          To
                                          Pankaj Chaturvedi <pankaj.c@thomsondigital.com>
                                          cc
                                          Subject
                                          Arivu..
                                          • 18. Re: With CS5, some things have changed
                                            Anil Yadav Level 1
                                            Tagging of Footnote Text is not supported in InDesign CS5. Please find below the screen shot for the same.
                                            • 19. Re: With CS5, some things have changed
                                              grefel Level 2
                                              Hey Dave,
                                              you forgot to handle placed XML Elements in your findPage function and made a mistake about the Cell case.
                                              With a selected Cell your switch statement selected the parentTextFrame and breaked the switch. After the break it would run into line
                                              The parent of pageItem gives you the Spread in InDesign CS5. I've found it wondering why my xml additon does not worked.
                                              I hope i've not introduced new Bugs
                                                        switch (whatIsIt) {
                                                             case Note : theObj = theObj.storyOffset.parentTextFrames[0]; break;
                                                             case XMLElement :  if (theObj.insertionPoints[0] != null) { theObj =  theObj.insertionPoints[0].parentTextFrames[0]; break; }
                                                             default: theObj = theObj.parent;
                                                   return theObj
                                              } // end findPage
                                              regards,
                                              gregor
                                              UPDATE: made an addition to the Note case  ...
                                              • 20. Re: With CS5, some things have changed
                                                Harbs. Level 6
                                                JPEGExportPreference.resolution became JPEGExportPreference.exportResolution
                                                • 21. Re: With CS5, some things have changed
                                                  Fred Goldman Level 3
                                                  I think it's worth noting doc.pages[x]textFrames.item("Label") still works. It's only if you try to get the item from the document object where it doesn't work anymore.
                                                  • 22. Re: With CS5, some things have changed
                                                    Harbs. Level 6
                                                    Good point. That's beacuse there's no name property for pages yet.
                                                    However, I think the issue with PageItems in CS5 drives home the point that it's not the best idea to use .item() with labels...
                                                    Who knows when Pages might get a name property...
                                                    Harbs
                                                    • 23. Re: With CS5, some things have changed
                                                      Harbs. Level 6
                                                      As Jongware points out here, PointType.LINE_TYPE is now PointType.PLAIN.
                                                      • 24. Re: With CS5, some things have changed
                                                        Harbs. Level 6
                                                        As pointed out here, there is no longer a property PasteBoardPreferences.minimumSpaceAboveAndBelow.
                                                        Use PasteBoardPreference.pasteboardMargins instead.
                                                        Harbs
                                                        • 25. Re: With CS5, some things have changed
                                                          GbHerff Level 1
                                                          I am using a javascript to export a pdf with settings. The script works fine in CS3 and CS4, but not CS5. I get an error from the following line of code for PDF preferences. I am exporting the PDF with OPI. What is the new syntax in CS5 for this setting?
                                                          contentToEmbed = PDFContentToEmbed.linkAll;
                                                          • 26. Re: With CS5, some things have changed
                                                            Larry G. Schneider Adobe Community Professional & MVP
                                                            Jongware's CS3 Help document lists the proper form for that command as PDFContentToEmbed.LINK_ALL. Have you tried that.
                                                            edit:  Looking at the similar Help files for CS5, this property seems to no longer be supported.
                                                            • 27. Re: With CS5, some things have changed
                                                              GbHerff Level 1
                                                              That didn't work. There has to be some javascript command to do this. It is still available in the PDF settings.
                                                              • 28. Re: With CS5, some things have changed
        Harbs. Level 6
        What error are you getting? Try using the numeric value instead of the constant...
        Harbs
        • 29. Re: With CS5, some things have changed
        GbHerff Level 1
        The error is PDFContentToEmbed is undefined. I don't know of any numeric value. This command tells InDesign to create OPI in the PDF for linked images.
        • 30. Re: With CS5, some things have changed
        The property itself is removed. I scanned the export settings by eye, then used a full text search, but couldn't locate something similar-with-a-slightly-different-name.
        • 31. Re: With CS5, some things have changed
        GbHerff Level 1
        I figured it out. I found the answer in Jongwares ID CS5 scripting help files. That command has been substituted with the omitBitmap, OmitEPS to look more like the PDF Export setting.
        • 32. Re: With CS5, some things have changed
        KreunKormann Level 1
        Hi everybody,
        I'm a vb script developer and I use to access TextFrames with labels, for instance :
        set oFrame = myPage.TextFrames.item("bText")
        it seems this method no longer exist in CS5... is it a bug ?
        Thanks in advance for your answers,
        Philippe
        • 33. Re: With CS5, some things have changed
        Peter Kahrel Adobe Community Professional & MVP
        This is dealt with earlier in this same thread.
        Peter
        • 34. Re: With CS5, some things have changed
        Thanks Peter,
        so here is the "traduction" of the code in VB to access a TextFrame with the label :
        Public Sub GetItemFromCollection(ByVal label As String, ByRef collection As InDesign.TextFrames, ByRef oTextFrame As InDesign.TextFrame)
        scriptVersion = oInd.ScriptPreferences.Version
        If scriptVersion > 6 Then oInd.ScriptPreferences.Version = 6
        Set oTextFrame = collection.Item(label)
        oInd.ScriptPreferences.Version = scriptVersion
        End Sub
        and to call it :
        Call GetItemFromCollection("bTexte", oPage.TextFrames, oTexteFrame)
        but it was easier before...
        Philippe
        • 35. Re: With CS5, some things have changed
        Pontus Uggla
        I cant my progress bar working in CS5, it works if i dont trigger it from the menu.
        Does anyone have a working script like this?
        Here is the script that i made that adds a menu and when you fire the submenu a progress bar should start working in a window, but nothing is happening except when i add an alert, then it fires.
        #targetengine "session"
        // Create menu item
        var test_menu = app.menus.item('$ID/Main').submenus.add('Test menu');
        // Create sub menu action
        var test_sub_menu = app.scriptMenuActions.add('Run progressbar');
        // Set on invoke action
        test_sub_menu.eventListeners.add('onInvoke', function() {
        // Create a simple window
        var win = new Window(
        "window { \
        progressbar: Progressbar { size: [400, 10] } \
        // Center and show the window
        win.center();
        win.show();
        // Set max value for the progressbar
        win.progressbar.maxvalue = 5;
        // Make a simple loop from 0 to 4
        for(var i = 0; i < 5; i++) {
        // This should happen every second
        win.progressbar.value = i;
        // Sleep for a second
        $.sleep(1000);
        // Remove the test menus actions
        app.scriptMenuActions.item('Run progressbar').remove();
        app.menus.item('$ID/Main').submenus.item('Test menu').remove();
        // Add the sub menu action
        test_menu.menuItems.add(test_sub_menu);
        • 36. Re: With CS5, some things have changed
        Andreas Jansson Level 2
        I just found a difference in the results from allPageItems, in CS5, which I have to code some kind of exception / condition for, in my scripts before upgrading them to CS5:
        allPageItems now includes "contained" objects (images and other linked objects, that reside inside rectangles and such) in CS5.
        As a simple test, placing an EPS on an empty page in a new document, I run the following code in CS4 and CS5 respectively:
        CS5:
        app.activeDocument.pages[0].allPageItems
        Result: [object Rectangle],[object EPS]
        CS4:
        As you can see, we get the container rectangle only, in CS4, while CS5 is returning the object contained as well.
        In a larger result set I get the following objects included in the allPageItems in CS5 (not present in the same call in CS4):
        [object Image]
        [object EPS]
        [object Polygon]
        [object PDF]
        -- Andreas
        • 37. Re: With CS5, some things have changed
        Harbs. Level 6
        Interesting. Thanks!
        I wonder if it has something to do with the introduction of spline items...
        Harbs
        • 38. Re: With CS5, some things have changed
        [object Image]
        [object EPS]
        [object Polygon]
        [object PDF]
        New "feature", ehh ...
        But this time - one thing could be good:
        [container]
        [content]
        I think it could be usefull ... there is no way for [content] to be without preceding [container] ...
        robin
        • 39. Re: With CS5, some things have changed
        brifilone Level 1
        I know this is an ancient post but just wondering if you got an answer on how to talk to boxs that have labels in CS5 I am just returning to the workforce and the last scripts I worked on were CS2 and my new company uses CS5. I'll repost my question below if you have any insights that would be great since we seem to have been in the same boat!
        I wrote an Applescript at home on my laptop where I only have Adobe CS2 and want to use the same thing at work to show my boss what is possible with Applescript and it is failing at work cause we have Adobe CS5. Specifically placing a picture in InDesign.
        This works in CS2 where I am talking to a named picture box
        set picToPlace to "ARTWORK:Close Ups:05-02-04:CUA2222.tif" as alias
        tell application "Adobe InDesign CS2"
        activate
        tell document 1
        place picToPlace on rectangle "photo1"
        fit rectangle "photo1" given proportionally
        end tell
        end tell
        But at work when it gets to the {place picToPlace on rectangle "photo1"} line it stops and says something about "cannot get alias" (and gives the whole path to the file I am trying to place.)
        Have they changed the wording for placing a pic in a rectangle? in CS5?
        1 2 3 Previous Next
