1 Reply Latest reply on Sep 16, 2007 10:29 PM by raghunathrao
    ..null object reference
    scrattis
      Getting this runtime error and cant get to work it out so that it wouldn't show this message. And it doesn't even show this message everytime! anyway. a hintaLaskuri -funtion is a function that I load at startup (error message shows then) and at every one second. Here is the error code and actual function:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at vaihtokaista2/::hintaLaskuri()
      at Function/ http://adobe.com/AS3/2006/builtin::apply()
      at ()
      at flash.utils::SetIntervalTimer/flash.utils:SetIntervalTimer::onTimer()
      at flash.utils::Timer/flash.utils:Timer::_timerDispatch()
      at flash.utils::Timer/flash.utils:Timer::tick()
      private function hintaLaskuri():void {
      var now:Date = new Date(); now.getTime()/1000;
      //Alert.show((NYT.getTime()/1000).toString());
      for (var i:int=0;i<xlAuto.length();i++) {
      if(xlAuto .Varaus[0] != 1) {
      if(xlAuto
      .LopetusPvm[0] < (now.getTime()/1000)+aikalatency) {
      var hintaMuutos:Number = 0;
      var hintaNyt:Number = xlAuto .LopetusHinta[0];
      delete xlAuto
      else {
      hintaMuutos = ((xlAuto .AloitusHinta[0] - xlAuto.LopetusHinta[0]) / (xlAuto .LopetusPvm[0] - xlAuto.AloitusPvm[0])) * (((now.getTime()/1000)+aikalatency - xlAuto .AloitusPvm[0]));
      hintaNyt = xlAuto
      .AloitusHinta[0]-hintaMuutos;
      xlAuto .HintaNyt[0] = hintaNyt;
      autotCol.refresh();
      var hintanumero:Number;
      var hintateksti:String;
      var numerot:Array;
      hintanumero = Number(autotCol.source.(Rekisteri[0] == suosituin[0]).HintaNyt);
      if(hintanumero < 10000)
      hintateksti = " " + autotCol.source.(Rekisteri[0] == suosituin[0]).HintaNyt.toString();
      else
      hintateksti = autotCol.source.(Rekisteri[0] == suosituin[0]).HintaNyt.toString();
      numerot = hintateksti.split("");
      l_1_1.text = numerot[0];
      l_1_2.text = numerot[1];
      l_1_3.text = numerot[2];
      l_1_4.text = numerot[3];
      l_1_5.text = numerot[4];
      l_1_6.text = ",";
      l_1_7.text = numerot[6];
      l_1_8.text = numerot[7];
        • 1. Re: ..null object reference
          raghunathrao Level 1
          Looking at your code... there are only a couple of variables that are external to this function. xlAuto, Rekisteri & autotCol seems to be it.
          Can you check if any of them are null (by putting a breakpoint in FlexBuilder and adding these variables to the variables watch window.
