1 Reply Latest reply on Apr 16, 2010 7:38 PM by Stephen Horne
    specifying objects based on applied paragraph styles
    Stephen Horne Level 1
      Hi, can anyone tell me where I'm going wrong with this? I want to set the bounds of a load of text frames scattered through a document to specific values, identifying them by the paragraph style applied to their (only) paragraph.
      tell application "Adobe InDesign CS3"
           tell document 1
                set geometric bounds of ¬
                every text frame of document 1 ¬
                whose applied paragraph style of paragraphs is "Crag Intros Left" to {3.880555555556, 6.99999800788, 10.0, 139.347222222222}
           end tell
      end tell
      it generates this error message:
      Adobe InDesign CS3 got an error: Can’t set geometric bounds of every text frame of selection of document 1 whose .....
        • 1. Re: specifying objects based on applied paragraph styles
          I've figured it out. The important part was to specify "name of applied paragraph style". I also use a repeat statement instead of telling the document to change everything in one go:
          tell document 1
               repeat with oneFrame in (get text frames whose name of applied paragraph style of paragraphs is "Crag Headings Left")
                    if geometric bounds of oneFrame is not {a, b, c, d} then
                         set geometric bounds of oneFrame to {a, b, c, d}
                    end if
               end repeat
          end tell
