1 Reply Latest reply on Apr 12, 2010 9:06 AM by hans-g.
    Help with Template and page title
    Bushido Level 1
      Sill having an issue, even after Murrays advice- see below.
      The child page titles keep disappearting upon 'save' - http://www.jhiggsaa.com/emailus.htm
      MURRAY'S ADVICE -----
      This is the sign of an improperly made template.
      Do this -
      Create a new page (Basic HTML).
      Use FILE | Save as Template....
      Look at the code in the head region of the page, particularly the editable
      region around the <title> tag, and the other editable region in the head
      called "head".
      Make your template file look like that.
      Always use FILE | Save as Template when you create your templates and you
      won't have this problem again.
        • 1. Re: Help with Template and page title
          hans-g. Adobe Community Professional & MVP
          well Murrays advice works in most cases. In your case you should talk with the p7tbm-people, from which the template comes.
          If you would like to use brute force:
          Copy the source code into a word processing program.
          Delete these characters : <! - And ->. (But beware, be careful cause some of them you will still need.
          Hans-G.
