0 Replies Latest reply on Apr 12, 2010 8:26 AM by Carol L. Frampton
    [svn:fx-4.x] 15341: TLF 1.1 Build 603
    Carol L. Frampton Level 2
      Revision: 15341
      Revision: 15341
      Author:   cframpto@adobe.com
      Date:     2010-04-12 08:26:18 -0700 (Mon, 12 Apr 2010)
      Log Message:
      TLF 1.1 Build 603
      • Fix 2598300 Bad width calculations when doing incremental compose if RichEditableText has no width specified.
      QE notes:
      Doc notes: None
      Bugs:
      Reviewed By:
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/air-config.xml
          flex/sdk/branches/4.x/frameworks/flex-config.xml
          flex/sdk/branches/4.x/frameworks/libs/textLayout.swc
          flex/sdk/branches/4.x/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCo mpose.as
      Added Paths:
          flex/sdk/branches/4.x/frameworks/rsls/textLayout_1.1.0.603.swf
      Removed Paths:
          flex/sdk/branches/4.x/frameworks/rsls/textLayout_1.1.0.602.swf
