2 Replies Latest reply on Apr 12, 2010 12:12 PM by jbucaran
    Multitouch in AIR 2.0 via Flash Builder 4: Registration point of sprites
    jbucaran
      I watched Lee Brimelow's tut on multi touch gesture applications and tried to accomplish the same using Flash Builder.
      I did and everything works great except by one thing, the registration point of the movie clips I dynamically create and use to populate the stage is not in the center so when I either increase/decrease the size of the square as well as rotate it, it doesn't do it from the center but from one of the corners, the default registration point. If I understand correctly, it's impossible to change the registration point via AS3. How can I reproduce the example in Flash Builder then?
      I appreciate your time and help.
      Jorge
