0 Replies Latest reply: Apr 12, 2010 12:32 PM by Darrell Loverin RSS
    [svn:fx-4.x] 15346: Generate a compiler warning for incorrect usage of modules and sub-applications .
    Darrell Loverin Adobe Employee
      Revision: 15346
      Revision: 15346
      Author:   dloverin@adobe.com
      Date:     2010-04-12 12:31:58 -0700 (Mon, 12 Apr 2010)
      Log Message:
      Generate a compiler warning for incorrect usage of modules and sub-applications.
      This fix generates a compiler warning when a module is referenced by name in another module or application. The problem with doing this that is it defeats the purpose of using a module because all the module dependencies are linked into the parent module or application. A warning is also generated when an application is directly referenced in a module or application. The recommended solution is to use an interface.
      This fix does not address the RTE directly but removing the module or application reference resolves the RTE.
      Limitation:
      The warning is limited to the case where source for the referenced module or application comes from the source path, not from a swc.
      QE notes: See above.
      Doc notes: None
      Bugs: SDK-26120
      Reviewer: Alex, Paul
      Tests run: checkintests, Modules, PerModuleStyles
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-26120
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/modules/ModuleBase.as
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.jav a
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/tools_en.properties
