0 Replies Latest reply on Apr 12, 2010 1:22 PM by Paul Reilly
    [svn:fx-trunk] 15350: * More package and class level javadoc.
    Paul Reilly Level 1
      Revision: 15350
      Revision: 15350
      Author:   preilly@adobe.com
      Date:     2010-04-12 13:22:21 -0700 (Mon, 12 Apr 2010)
      Log Message:
      • More package and class level javadoc.  A small amount of commented
        out and dead code removal, too.
      QE notes:
      Doc notes:
      Bugs: N/A
      Reviewer: Corey
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/BytecodeEmitter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/CodeFragmentLogAdapter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/CodeFragmentsInputBuffer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/HostComponentExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/InheritanceEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/MetaDataEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/MetaDataParser.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/OffsetInputBuffer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SkinPartEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SkinPartExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/StyleEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/StyleExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/ArrayElementWatcher.j ava
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableExtension.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEval uator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableSecondPassEva luator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/ChangeEvent.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/ClassInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/EvaluationWatcher.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/FunctionReturnWatcher .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/Info.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/InterfaceInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/PrefixedPrettyPrinter .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/PropertyWatcher.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/RepeaterComponentWatc her.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/RepeaterItemWatcher.j ava
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/Watcher.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/XMLWatcher.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/package.html
