0 Replies Latest reply on Sep 7, 2007 9:35 AM by robert.ross
    TileList Drag/Drop functionality is broken if the same item is dropped twice or more
    robert.ross Level 1
      Hi Folks.
      This is quite frustrating.
      I'm using two tilelists and you can drag items from one to the other.
      If you drag an item more than once then when you rollover that item it highlights the second(or most recent) version of the item you dragged.
      Basically the second tile list is containing exact copies of the first, so that when you rollover an item it is behaving as if only the most recent addition to the component is there.
      Here is the code.
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" width="560" height="341">
      <mx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      [Bindable]
      private var listArray:Array=[
      {label: "item0", data: 0},{label: "item1", data: 1},
      {label: "item2", data: 2},{label: "item3", data: 3},
      {label: "item4", data: 4},{label: "item5", data: 5},
      {label: "item6", data: 6},{label: "item7", data: 7}];
      [Bindable]
      public var cartFilterCol:ArrayCollection ;
      </mx:Script>
      <mx:Canvas width="568" height="340">
      <mx:TileList
      id="filterTilelist"
      direction="vertical"
      dataProvider="{listArray}"
      itemRenderer="mx.controls.Button"
      allowMultipleSelection="false"
      dragEnabled="true"
      width="219"
      borderStyle="inset" height="228" x="48" y="36">
      </mx:TileList>
      <mx:TileList backgroundColor="#ffffff"
      dataProvider="{cartFilterCol}"
      dropEnabled="true"
      dragMoveEnabled="true"
      dragEnabled="true"
      borderStyle="inset"
      columnCount="1"
      height="228" width="194" x="275" y="36">
      </mx:TileList>
      </mx:Canvas>
      </mx:Application>
      I think this is the issue here
      https://bugs.adobe.com/jira/browse/SDK-11894
      It seems to suggest that this issue is resolved but it doesn't go into details. Can anybody help me, even an ugly hack would do? Have tried several things like manually setting the mx_internal_uid on object beign dragged before it is dropped but no luck so far. I'm using Flex builder 2.0.1.
      Rob
