2 Replies Latest reply on Apr 13, 2010 9:13 PM by Vikash.kumar29
    how to refer mxml in Actionscript class.
    vipin.nemade
      hello friends,
      I have created small application for login in flex desktop application. In which I am refering webservice method for login for this have created the Authentication class. Now I want to refer different  Textinput value for mobile no and Textinput value for password. In my Authentication class.
      for this I have created the object of mxml class.And using this I am getting the mobile no value and password value in My Action script class.
      This my code :-
      SBTS.mxml file
      <!-- usingas/AccessingPackagedClasses.mxml -->
      <mx:WindowedApplication
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Script>
      <![CDATA[
      public
      function login():void
      var User:Authentication;
      User =
      new Authentication();
      User.authentication();
      </mx:Script>
      <mx:Panel width="100%" height="100%" layout="absolute">
      <mx:TabNavigator width="100%" height="100%" id="viewstack2">
      <mx:Form label="Login Form" id="loginform">
      <mx:FormItem label="Mobile no:">
      <mx:TextInput id="mobileno"/>
      </mx:FormItem>
      <mx:FormItem label="Password:">
      <mx:TextInput displayAsPassword="true" id="password" />
      </mx:FormItem>
      <mx:FormItem>
      <mx:Button label="Login" click="login()"/>
      </mx:FormItem>
      </mx:Form>
      <mx:Form label="Child List">
      <mx:Label width="100%" color="blue"
      text="
      Select Child."/>
      </mx:Form>
      </mx:TabNavigator>
      </mx:Panel>
      </mx:WindowedApplication>
      Action script class :-
      package
      src
      import adobe.utils.XMLUI;
      import generated.webservices.*;
      import mx.collections.ArrayCollection;
      import mx.controls.Alert;
      import mx.rpc.events.FaultEvent;
      public class Authentication
      Bindable]
      private var childName:ArrayCollection;
      Bindable]
      private var childId:ArrayCollection;
      private var photoFeed:ArrayCollection;
      private var arrayOfchild:Array;
      private var newEntry:GetSBTSMobileAuthentication;
      public var user:SBTSWebService;
      public var mxmlobj:SBTS;
      public function authentication():void
      user =
      new SBTSWebService();
      if(user!=null)
      user.addSBTSWebServiceFaultEventListener(handleFaults);
      user.addgetSBTSMobileAuthenticationEventListener(authenticationResult);
      newEntry =
      new GetSBTSMobileAuthentication();
      if(newEntry!=null)
      mxmlobj =
      new SBTS();
      if(mxmlobj != null)
      newEntry.mobile = mxmlobj.mobileno.text; // Getting error here   error mention below
        newEntry.password= mxmlobj.password.text;
      user.getSBTSMobileAuthentication(newEntry);
      public function handleFaults(event:FaultEvent):void
      Alert.show(
      "A fault occured contacting the server. Fault message is: " + event.fault.faultString);
      public function authenticationResult(event:GetSBTSMobileAuthenticationResultEvent):void
      if(event.result != null && event.result._return>0)
      if(event.result._return > 0)
      var UserId:int = event.result._return;
      if(mxmlobj != null)
      mxmlobj.loginform.enabled =
      false;
      mxmlobj.viewstack2.selectedIndex=1;
      else
      Alert.show(
      "Authentication fail");
      I am getting this error :-
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at SBTSBusineesObject::Authentication/authentication()[E:\Users\User1\Documents\Flex Builder 3\SBTS\src\SBTSBusineesObject\Authentication.as:35]
      at SBTS/login()[E:\Users\User1\Documents\Flex Builder 3\SBTS\src\SBTS.mxml:12]
      at SBTS/___SBTS_Button1_click()[E:\Users\User1\Documents\Flex Builder 3\SBTS\src\SBTS.mxml:27]
      please help me to remove this error.
        • 1. Re: how to refer mxml in Actionscript class.
          radikalFish
          Hi
          You have an instantiation like this
          mxmlobj =
          new SBTS();
          and immediately you are trying to access one of its childs via
          this might not been created at this moment
          you have to wait for the "creation_complete" event fired for this component like
          mxmlobj.addEventListener(FlexEvent.CREATION_COMPLETE, onCreationComplete, false, 0, true);
          and inside that event handler you can access its childs
          protected function onCreationComplete(ev:Event):void {
          does this work?
          P.S.
          There might spelling errors i ve just typed an answer without testing...
          • 2. Re: how to refer mxml in Actionscript class.
            Vikash.kumar29
            You said :
            if(newEntry!=null)
            mxmlobj =
            new SBTS();
            if(mxmlobj != null)
            //------ Your rest of code
            but SBTS is you top WindowApplication mxml object. So saying
            mxmlobj = new SBTS();
            will create new Instance of SBTS class and not contain your original value shown in UI.
            You can do this by saying
            <mx:Script>
            <![CDATA[
            public
            User = new Authentication();
            User.authentication(this); // note we have passed reference of SBTS class
            </mx:Script>
            Now modify your class Authentication like
            public function authentication(inSbts:SBTS):void
            mxmlobj = inSbts // assign the refernce here
            user = new SBTSWebService();
            ------------ Your Original Code --------------------------------------
            if(newEntry!=null)
            //mxmlobj = new SBTS();  no need of doing this as we have reference of window application/UI
            if(mxmlobj != null)
            newEntry.mobile = mxmlobj.mobileno.text; // Since mxmlObj is already added to stage to will not any error
            ---- -------------------Your rest of code -------------------------------------------------
            Now you are done, and hope this will solve your problem.
            Cheers
            -Vikash
