3 Replies Latest reply on Sep 18, 2007 4:43 AM by Newsgroup_User
    Login Behavior Part Two...
    rossmgreenberg
      So, I finally figured out how to get the actual record number selected with the login, and I'm sticking it into a session variable. I'm surprised that DreamWeaver doesn't make it easier!
      I ended up having to go into the login behavior and modify the source code! When I do so the login behavior seems to disappear although the code does not: how can I modify the code and not lose the "log in" behavior in the behaviors window?
      Ross
        • 1. Re: Login Behavior Part Two...
          Level 7
          "rossmgreenberg" <webforumsuser@macromedia.com> wrote in message
          news:fckcbh$j2v$1@forums.macromedia.com...
          > with the
          > code!
          > not:
          > behaviors
          > window?
          > Ross
          You'd have to rewrite the code so that the login behavior's regular
          expressions still match the code,
          most regular expressions contain expressions for a negative match on
          linebreaks: ([^\r\n]*?)
          so appending your changes without inserting a linebreak should work most of
          the time.
          • 2. Re: Login Behavior Part Two...
            rossmgreenberg Level 1
            That makes perfect sense! What is the best way of inserting a line delimiter on the same line?
            Ross
            • 3. Re: Login Behavior Part Two...
              Level 7
              news:fco8cr$2f1$1@forums.macromedia.com...
              > Ross
              in PHP, JSP, ASP_JScript and ASP.NET_CS you can insert a semicolon (;)
              doThis();doThat();
              in ASP_VBS and ASP.NET_VB you can use the colon (:)
              doThis():doThat()
