12 Replies Latest reply on Apr 14, 2010 5:47 PM by spirito78
    XML menu
    spirito78
      Hello,
      I am trying to use the (frame function). I am having a problem with the action script.  It's not going to the next frame.
      Can someone please help me out on this. It sounds simple but I am missing something.
      Tom
      Actionscript
      Code menu_mc.onItemClick= function(node:XMLNode, level:Number)
      { my_movie_clip.gotoAndStop(Number(node.attributes  .frame))
      XML DATA:
      <menu>
      <item label="Home" frame="1"/>
      <item label="About Us" frame="2" />
      <item label="Cosmetic Procedures" />
      <item label="Cosmetic Surgery" />
      <item label="Dermatological Services" />
      <item label="New Patient Forms" />
      <item label="Medical grade Products" />
      <item label="Contact" />
      <item label="Monthly Specials" />
      </menu>
        • 1. Re: XML menu
          show your code that loads and parses your xml.
          • 2. Re: XML menu
            spirito78 Level 1
            Stage.scaleMode = "noScale";
            Stage.showMenu = false;
            Stage.align = "TL";
            // CLICK HANDLER FUNCTION
            menu_mc.onItemClick = function(node:XMLNode, level:Number) {
                res_txt.text = "Label> "+node.attributes.label+" | Menu item level> "+level;
            // LOAD XML AND GENERATE MENU
            var xob:XML = new XML();
            xob.ignoreWhite = true;
            xob.onLoad = function(s) {
                if (!s) {
                    trace("Error loading xml file !");
                    return;
                menu_mc.data = this.firstChild;
            xob.load("data.xml");
            • 3. Re: XML menu
              node is undefined in your function.  and you have duplicate onItemClick() methods.
              • 4. Re: XML menu
                spirito78 Level 1
                        kglad,
                        Could you give me example. Is it something like this.
                • 5. Re: XML menu
                  you should be doing something like:
                  Stage.align = "TL";
                  menu_mc.onRelease = function() {
                  // i have no idea what level is
                      res_txt.text = "Label> "+xob.firstChild.childNodes[0].attributes.label+" | Menu item level> "+level;
                      if (!s) {
                          return;
                  • 6. Re: XML menu
                    spirito78 Level 1
                    Sorry it didn't work. It won't  advance to the next fame.
                    • 7. Re: XML menu
                      are you still using that duplicate function code?
                      • 8. Re: XML menu
                        spirito78 Level 1
                        this is what I have
                        Stage.align = "TL";
                        menu_mc.onItemClick= function(node:XMLNode, level:Number){
                        _root.home_mc.gotoAndStop(Number(node.attributes.frame));
                        _root.about_us_mc.gotoAndStop(Number(node.attributes.frame));
                            if (!s) {
                                return;
                        • 9. Re: XML menu
                          that code shows you've understood and/or read nothing that i've posted.
                          • 10. Re: XML menu
                            spirito78 Level 1
                            Here is my fla file. I don't understand I added onRelease and the
                            highlight does work so I put the code back
                            • 11. Re: XML menu
                              robdillon Most Valuable Participant
                              I found this link to a very similar problem: http://forum.oxylusflash.com/2-levels-accordion-menu/3197-links-not-working-no-idea-why.ht ml
                              Have a read through that and see if it helps to solve the problem.
                              • 12. Re: XML menu
                                spirito78 Level 1
                                Everyone thanks I figure it out
