For a course I'm creating, the SABA LMS Completion Status is always “Successful” even if just 1 slide of the Scorm 1.2 compliant Adobe Presenter course is viewed – doesn’t even need to get into quiz.
A failing grade is also always "Successful". How to get an "Unsuccessful" for skipping the quiz and/or failing the quiz?
Settings:
Reporting - Quiz Manager:
Enable reporting for this project -- checked
Learning Managemenet System (LMS) -- Scorm
Choose Report Data -- Report Quiz results only
Report Pass or Fail -- Report Pass/Fail (should this be Report staus as defined by report data?)
Report Score to LMS as: Percent
Reporting Level -- Report interactions and the score
A tweak has fixed this such that the course needs to be viewed as well as the quiz... but the Completion Status gets set for "Successful" even if there is a failing grade. The transcript will say "Successful" even though there the Pass/Fail options are set. Any ideas of how to get an "Unsuccessful"?
Hello,
Did you ever figure out a workaround for Saba always marking a completion status of "Successful" regardless of the leaner's score? I'm running into the same issue with some third-party content. Regardless of my score in relation to the mastery score, the test courses keep sending a completion status of "Successful." Our home-grown content works and sends an "Unsuccessful" completions status so I'm trying to give the vendor a hint as to what they can fix in their content. Please post if you have.... Kind Regards
Please upload content to http://cloud.scorm.com. Create a account and upload content to this. Do all the steps which you did in SABA server. If you still see wrong status then we have to look the the course created by Presenter. But if course show correct status in Scorm.com; then you need to conatct SABA support.
SCORM.com site properly compliance to all the SCORM standards.
Regards,
Shubhi
I have Presenter courses working properly in Saba. Sometimes the issue is your Offering or Content settings in Saba. Could be a combo of having Is Scoring checked and having a Mastery Score set on Course or Offering level.
When you dig down into the Activity History for that transcript completion, what status is listed on the module level? Saba will roll up to a status of Successful/Unsuccessful/Not Evaluated depending on how you have it setup. What Status is your content actually passing back: Completed, Incomplete, Passed, Failed?
Good Luck!
