2 Replies Latest reply on Sep 18, 2007 8:12 AM by Rylz
    Change movie size when using loadMovie
      I'm pulling in an external SWF (Flash Paper), replacing an existing MC. The MC dimensions are 600x300; however, the Flash Paper SWF is 450x700. Since Flash Paper only creates an SWF, is there a way I can pass credentials in loadMovie to change the size of the Flash Paper SWF? Right now, I've got
      loadMovie('newsletter/newsletter.swf', 'newsBox');
      Can anything be added in there to dynamically change the size? Thanks!
        • 1. Re: Change movie size when using loadMovie
          SymTsb Level 2
          this is a limitation of loadMovie. However, if you are using Flash 8 or CS3 AS2, you have access to a class called MovieClipLoader which does have the ability to provide you such functionality since you can actually fire off an event to resize after the external swf is loaded.
          • 2. Re: Change movie size when using loadMovie
            Rylz Level 1
            OK, after reading through what MovieClipLoader can do, how would I structure the code to resize the MC? Please advise/elaborate as I don't know what to put in the { } :
            MovieClipLoader.loadMovie('newsletter.swf', 'newsBox');
            MovieClipLoader.onLoadInit = function('newsBox'){
