How to Move in Y axis column
JaxNa Apr 13, 2010 7:23 PM
this is a code of creting a grid.
//************************************************Reel Code START*****************************************
var my_str:String = "1,2,3,4,5,6,7,8,9,10,1,2,3,4,5";
var display_array:Array = my_str.split(",");
_global.speed = 200;
_global.counter = 0;
_global.WheelInterval = 100;
_global.pressnextbtn = false;
_global.pressPrebtn = false;
_global.pressnextbtnBet = false;
_global.pressPrebtnBet = false;
_global.lines = 25;
txt_lines.text = 25;
onEnterFrame = function () {;
if (_global.pressnextbtn == true) {
if (_global.lines<25) {
_global.lines = _global.lines+1;
txt_lines.text = _global.lines;
if (_global.pressPrebtn == true) {
if (_global.lines>1) {
_global.lines = _global.lines-1;
if (_global.pressnextbtnBet == true) {
if (_global.linesbet<100) {
_global.linesbet = _global.linesbet+1;
txt_bet.text = "0."+_global.linesbet;
if (_global.linesbet == 100) {
txt_bet.text = "1.00";
if (_global.pressPrebtnBet == true) {
if (_global.linesbet>1) {
_global.linesbet = _global.linesbet-1;
nextline_btn.onPress = function() {
_global.pressnextbtn = true;
nextline_btn.onRelease = function() {
prevline_btn.onPress = function() {
_global.pressPrebtn = true;
prevline_btn.onRelease = function() {
_global.linesbet = 1;
nextlinebet_btn.onPress = function() {
_global.pressnextbtnBet = true;
nextlinebet_btn.onRelease = function() {
prevlinebet_btn.onPress = function() {
_global.pressPrebtnBet = true;
prevlinebet_btn.onRelease = function() {
//****************************************Dot Net Variable**********************************************
var reel_array:String = ("3,1,2,7,10,8,6,7,4,2,3,8,5,3,1,9,@10,6,1,8,4,3,5,9,1,2,2,8,3,7,3,7,@2,4,2,1,1 ,3,8,3,7,10,9,3,8,7,5,6,@2,6,5,8,1,7,2,9,4,10,3,8,7,1,3,3,@8,3,4,1,7,2,1,2,10,8, 6,3,3,9,7,5,@");
var my_array:Array = reel_array.split("@");
var randomno:Array = new Array(my_array.length-1);
var reel_array:Array = new Array(my_array.length-1);
for (var k = 0; k<(my_array.length-1); k++) {
reel_array[k] = my_array[k].split(",");
randomno[k] = random(16);
_root.createEmptyMovieClip("sq_mc",this.getNextHighestDepth());
sq_mc._x = 147;
sq_mc._y = 336;
var myObj:Object = new Object();
myObj.rows = 16;
myObj.columns = 5;
myObj.space = 61;
myObj.depth = 1;
myObj.path = _root.sq_mc;
function createGrid():Void {
for (var j:Number = 0; j<myObj.rows; ++j) {
for (var i:Number = 0; i<myObj.columns; ++i) {
var name:String = "cell"+i+"_"+j;
var x:Number = (i)*myObj.space;
var y:Number = (j)*myObj.space;
myObj.path.attachMovie("box_mc",name,++myObj.depth);
myObj.path[name]._x = x;
myObj.path[name]._y = -y;
myObj.path[name].createEmptyMovieClip("holder_mc",this.getNextHighestDepth());
var ind:Number = randomno[i]+(j-1);
if (ind<0) {
ind = 15;
} else if (ind>15) {
ind = 0;
myObj.path[name].holder_mc.loadMovie("images/jackpot/"+reel_array[i][ind]+".jpg ");
createGrid();
spinImages = function () {
for (var k = 0; k<(randomno.length); k++) {
var n:Number = randomno[k];
if (n<15) {
randomno[k] = n+1;
} else {
randomno[k] = 0;
setImages();
_global.counter = _global.counter+10;
if (_global.counter<_global.speed) {
setTimeout(this,'spinImages',_global.WheelInterval);
} else {
displayImages();
btnSpin.onRelease = function() {
spinImages();
setImages = function () {
var str:String = "cell"+i+"_"+j;
if (ind<0) {
ind = 15;
ind = 0;
myObj.path[str].holder_mc.loadMovie("images/jackpot/"+reel_array[i][ind]+".jpg" );
myObj.path[str].holder_mc._alpha = 100
displayImages = function () {
for (var j:Number = 0; j<myObj.rows; j++) {
for (var i:Number = 0; i<myObj.columns; i++) {
myObj.path[str].holder_mc.loadMovie("images/jackpot/"+display_array[i+(j*5)]+". jpg");
heighLight()
//******************************************HeighLight Image********************************************
this.createEmptyMovieClip("line_mc",this.getNextHighestDepth());
line_mc.lineStyle(2,0x00000,100);
var line_details:Array =new Array(25);
line_details[0] = "2,2,2,2,2,";
line_details[1] = "1,1,1,1,1,";
line_details[2] = "3,3,3,3,3,";
for(var i=3; i<line_details.length;i++){
line_details[i] = "2,2,2,2,2,";
var reelBlink_string:String = ("Line:1:0.1:2,Line:2:0.1:3,Line:3:0.1:4,");
var lines_array:Array = reelBlink_string.split(",");
var reelBlink_array:Array = new Array(4);
heighLight=function(){
for (var k = 0; k<(lines_array.length-1); k++) {
reelBlink_array = lines_array[k].split(":");
var line_no:Number = reelBlink_array[1];
var high:Number = reelBlink_array[3];
var line_string = line_details[line_no-1];
var col_array:Array = line_string.split(",");
for (var n:Number=0;n<high;n++){
var str:String = "cell"+n+"_"+(col_array[n]-1);
myObj.path[str].holder_mc._alpha = 30
//************************************************Reel Code END*****************************************
Any one help me plz.
i want to spin grid of colum on button relese..
now i have done only changed images in column on button relese.
but i want move in Y-axis from top to bottom.
Please help me..
