0 Replies Latest reply on Apr 14, 2010 6:03 AM by Paul Reilly
    [svn:fx-trunk] 15412: * More package and class level javadoc for the
    Paul Reilly Level 1
      Revision: 15412
      Revision: 15412
      Author:   preilly@adobe.com
      Date:     2010-04-14 06:03:45 -0700 (Wed, 14 Apr 2010)
      Log Message:
      • More package and class level javadoc for the
        flex2.compiler.as3.[binding,genext,managage,reflect] packages.  A
        small amount of commented out and dead code remove, too.  I also
        tightened the access permissions on a few things to make it more
        clear where they were used.
      QE notes:
      Doc notes:
      Bugs: N/A
      Reviewer: Corey (post-checkin)
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Transcoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/CodeFragmentsInputBuffer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableSecondPassEva luator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/WatcherSetupUtil.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeClassInfo.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeExtension.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeFirstPassEva luator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/PositionResetEvaluator .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedClassInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedExtensionError .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedFirstPassEvalu ator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedSecondPassEval uator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/As3Class.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Attributes.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/MetaData.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Method.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Namespace.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/NodeMagic.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Variable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/DocumentInfo.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/package.html
