1 Reply Latest reply on Apr 14, 2010 10:16 AM by ilssac
    CFDIV Animation?
    jeremy@noble Level 1
      I'm building a custom calendar application and I'd like to have each month animate on screen as the user navigates through them  (with a slide from the left or right) .
      Is it possible to use CFDIV and do this animation, or should I use jQuery instead?
      Thanks.
        • 1. Re: CFDIV Animation?
          ilssac Level 5
          Yes.
          Yes or something like it.
          <cfdiv...> does not do anything special on the Client.  It is a server based 'wizard' like tool that just creates normal HTML div, CSS styles and JavaScript logic for you to be delivered to the client.  There is little preventing you from adding your own logic to the code created by ColdFusion.  You would just have to be careful that what you add does not interfere or override what ColdFusion is doing, unless that is your intention.
