1 Reply Latest reply on Sep 16, 2007 4:02 PM by kglad
    Embed[] search path
      Hi, I have a few embedded assets:
      [Embed(source="button.png")] private var btnImg:Class;
      var b:Bitmap = new btnImg() as Bitmap;
      However, I can't seem to add something to the search path that the Embed tag uses to locate resources.
      There's the additional problem that my .as file is referenced from another file, e.g:
      project1\MyButton.as -- has the embed tag
      project2\client.as -- has a MyButton() control
      project2\skin\* -- is where Embed[] should look for assets, including those found in MyButton.as
      this is my command line:
      %SDKPATH%\bin\mxmlc.exe "%SRCFILE%" -compiler.source-path=%COMMON_CLASSES%
      Where SDKPATH is where the flex-2.0.1 SDK is, SRCFILE is the full path to 'client.as' and COMMON_CLASSES refers to the 'project1' directory. Ideally, I should be able to add another parameter:
