5 Replies Latest reply on Apr 14, 2010 6:15 PM by Joshfromdallas
    FLEX 3 PHP TCPDF QUESTION
    Joshfromdallas
      If i make a Datagrid with PHP i have this code:
      <h2>Submitted forms</h2>
              <table>
                <tr>
                 <th>Date</th>
                  <th>Order ID</th>
                  <th>Store ID</th>
                  <th>Route ID</th>
                  <th>Tech ID</th>
                  <th>Download PDF</th>
                </tr>
              <?php
        // Start row counter
        $iRow = 0;
        // Loop through all the rows in the database
              while ($orders = mysql_fetch_array($result)) {
         $iRow++; // Increase counter
         $rowColor = ($iRow % 2) ? "" : "class=\"even\""; // If the row is even, put a CSS class on it
                <tr <?php echo $rowColor; // actually put the rowColor class name ?>>
                  <td><?php echo $orders["date"]; ?></td>
                  <td><?php echo $orders["id"]; ?></td>
                  <td><?php echo $orders["store_id"]; ?></td>
                  <td><?php echo $orders["route_id"]; ?></td>
                  <td><?php echo $orders["tech_id"]; ?></td>
                  <td><a href="getorder.php?id=<?php echo $orders['id']; //Download page in this case uses the primary key of the row to select the data to create the pdf. ?>">Download</a></td>
                </tr>
              <?php
              // Close loop
      I have a column named Download that has a link that runs a php that builds a PDF File and gives it to the user. It works great as above, but I would love to use flex to build an app to do this.
      Problem is, I don't understand where I need to add this code in FLEX3. I have just done a simple project where I bult a datagrid that pulls from the MYSQL Database. I am able to add a column with header DOWNLOAD and I see the place where it builds an array, I guess I don't know the syntax to add the link into the array.
      I can add more script if needed and greatly apprecite any help
        • 1. Re: FLEX 3 PHP TCPDF QUESTION
          Matt Le Fevre Level 4
          i have a simple app here that reads information from a database and puts it into a flex datagrid, source code included
          http://www.mattlefevre.com/viewExample.php?tut=flexPHP&proj=Simple%20Login%20Application
          • 2. Re: FLEX 3 PHP TCPDF QUESTION
            Joshfromdallas Level 1
            Thanks for the link, I am trying to
            figure out how to accomplish what I need to do from it.
            Here is the php code that Flex generated:
            <?php
            require_once(dirname(__FILE__) . "/Mascotordersconn.php");
            require_once(dirname(__FILE__) . "/functions.inc.php");
            require_once(dirname(__FILE__) . "/XmlSerializer.class.php");
            * This is the main PHP file that process the HTTP parameters,
            * performs the basic db operations (FIND, INSERT, UPDATE, DELETE)
            * and then serialize the response in an XML format.
            * XmlSerializer uses a PEAR xml parser to generate an xml response.
            * this takes a php array and generates an xml according to the following rules:
            * - the root tag name is called "response"
            * - if the current value is a hash, generate a tagname with the key value, recurse inside
            * - if the current value is an array, generated tags with the default value "row"
            * for example, we have the following array:
            * $arr = array(
            *  "data" => array(
            *   array("id_pol" => 1, "name_pol" => "name 1"),
            *   array("id_pol" => 2, "name_pol" => "name 2")
            *  "metadata" => array(
            *   "pageNum" => 1,
            *   "totalRows" => 345
            * we will get an xml of the following form
            * <?xml version="1.0" encoding="ISO-8859-1"?>
            * <response>
            *   <data>
            *     <row>
            *       <id_pol>1</id_pol>
            *       <name_pol>name 1</name_pol>
            *     </row>
            *     <row>
            *       <id_pol>2</id_pol>
            *       <name_pol>name 2</name_pol>
            *     </row>
            *   </data>
            *   <metadata>
            *     <totalRows>345</totalRows>
            *     <pageNum>1</pageNum>
            *   </metadata>
            * </response>
            * Please notice that the generated server side code does not have any
            * specific authentication mechanism in place.
            * The filter field. This is the only field that we will do filtering after.
            $filter_field = "store_name";
            * we need to escape the value, so we need to know what it is
            * possible values: text, long, int, double, date, defined
            $filter_type = "text";
            * constructs and executes a sql select query against the selected database
            * can take the following parameters:
            * $_REQUEST["orderField"] - the field by which we do the ordering. MUST appear inside $fields.
            * $_REQUEST["orderValue"] - ASC or DESC. If neither, the default value is ASC
            * $_REQUEST["filter"] - the filter value
            * $_REQUEST["pageNum"] - the page index
            * $_REQUEST["pageSize"] - the page size (number of rows to return)
            * if neither pageNum and pageSize appear, we do a full select, no limit
            * returns : an array of the form
            * array (
            *   data => array(
            *    array('field1' => "value1", "field2" => "value2")
            *   metadata => array(
            *    "pageNum" => page_index,
            *    "totalRows" => number_of_rows
            function findAll() {
            global $conn, $filter_field, $filter_type;
              * the list of fields in the table. We need this to check that the sent value for the ordering is indeed correct.
            $fields = array('id','store_id','date','route_id','tech_id','store_name',);
            $where = "";
            if (@$_REQUEST['filter'] != "") {
              $where = "WHERE " . $filter_field . " LIKE " . GetSQLValueStringForSelect(@$_REQUEST["filter"], $filter_type);
            $order = "";
            if (@$_REQUEST["orderField"] != "" && in_array(@$_REQUEST["orderField"], $fields)) {
              $order = "ORDER BY " . @$_REQUEST["orderField"] . " " . (in_array(@$_REQUEST["orderDirection"], array("ASC", "DESC")) ? @$_REQUEST["orderDirection"] : "ASC");
            //calculate the number of rows in this table
            $rscount = mysql_query("SELECT count(*) AS cnt FROM `SALLY_ORDERS` $where");
            $row_rscount = mysql_fetch_assoc($rscount);
            $totalrows = (int) $row_rscount["cnt"];
            //get the page number, and the page size
            $pageNum = (int)@$_REQUEST["pageNum"];
            $pageSize = (int)@$_REQUEST["pageSize"];
            //calculate the start row for the limit clause
            $start = $pageNum * $pageSize;
            //construct the query, using the where and order condition
            $query_recordset = "SELECT id,store_id,date,route_id,tech_id,store_name FROM `SALLY_ORDERS` $where $order";
            //if we use pagination, add the limit clause
            if ($pageNum >= 0 && $pageSize > 0) {
              $query_recordset = sprintf("%s LIMIT %d, %d", $query_recordset, $start, $pageSize);
            $recordset = mysql_query($query_recordset, $conn);
            //if we have rows in the table, loop through them and fill the array
            $toret = array();
            while ($row_recordset = mysql_fetch_assoc($recordset)) {
              array_push($toret, $row_recordset);
            //create the standard response structure
            $toret = array(
              "data" => $toret,
              "metadata" => array (
               "totalRows" => $totalrows,
               "pageNum" => $pageNum
            return $toret;
            * constructs and executes a sql count query against the selected database
            * array (
            *   data => number_of_rows,
            *   metadata => array()
            function rowCount() {
            $where = "";
            $toret = array(
              "data" => $totalrows,
              "metadata" => array()
            return $toret;
            * constructs and executes a sql insert query against the selected database
            * $_REQUEST["field_name"] - the list of fields which appear here will be used as values for insert.
            * If a field does not appear, null will be used.
            * array (
            *   data => array(
            *    "primary key" => primary_key_value,
            *    "field1" => "value1"
            function insert() {
            global $conn;
            //build and execute the insert query
            $query_insert = sprintf("INSERT INTO `SALLY_ORDERS` (id,store_id,date,route_id,tech_id,store_name) VALUES (%s,%s,%s,%s,%s,%s)" ,   GetSQLValueString($_REQUEST["id"], "int"), #
               GetSQLValueString($_REQUEST["store_id"], "int"), #
               GetSQLValueString($_REQUEST["date"], "text"), #
               GetSQLValueString($_REQUEST["route_id"], "int"), #
               GetSQLValueString($_REQUEST["tech_id"], "int"), #
               GetSQLValueString($_REQUEST["store_name"], "text")#
            $ok = mysql_query($query_insert);
            if ($ok) {
              // return the new entry, using the insert id
              $toret = array(
               "data" => array(
                array(
                 "id" => $_REQUEST["id"],
                 "store_id" => $_REQUEST["store_id"], #
                 "date" => $_REQUEST["date"], #
                 "route_id" => $_REQUEST["route_id"], #
                 "tech_id" => $_REQUEST["tech_id"], #
                 "store_name" => $_REQUEST["store_name"]#
            } else {
              // we had an error, return it
              $toret = array(
               "data" => array("error" => mysql_error()),
            return $toret;
            * constructs and executes a sql update query against the selected database
            * $_REQUEST[primary_key] - thethe value of the primary key
            * $_REQUEST[field_name] - the list of fields which appear here will be used as values for update.
            * array (
            *   data => array(
            function update() {
            global $conn;
            // check to see if the record actually exists in the database
            $query_recordset = sprintf("SELECT * FROM `SALLY_ORDERS` WHERE id = %s",
            $num_rows = mysql_num_rows($recordset);
            if ($num_rows > 0) {
              // build and execute the update query
              $row_recordset = mysql_fetch_assoc($recordset);
              $query_update = sprintf("UPDATE `SALLY_ORDERS` SET store_id = %s,date = %s,route_id = %s,tech_id = %s,store_name = %s WHERE id = %s",
               GetSQLValueString($_REQUEST["store_name"], "text"),
               GetSQLValueString($row_recordset["id"], "int")
              $ok = mysql_query($query_update);
              if ($ok) {
               // return the updated entry
               $toret = array(
                "data" => array(
                 array(
                  "id" => $row_recordset["id"],
              } else {
               // an update error, return it
               $toret = array(
            } else {
              $toret = array(
               "data" => array("error" => "No row found"),
            return $toret;
            * array (
            *   data => deleted_row_primary_key_value,
            function delete() {
            global $conn;
              $query_delete = sprintf("DELETE FROM `SALLY_ORDERS` WHERE id = %s",
              $ok = mysql_query($query_delete);
              if ($ok) {
               // delete went through ok, return OK
               $toret = array(
                "data" => $row_recordset["id"],
              } else {
               $toret = array(
            } else {
              // no row found, return an error
              $toret = array(
            return $toret;
            * we use this as an error response, if we do not receive a correct method
            $ret = array(
            "data" => array("error" => "No operation"),
            * check for the database connection
            if ($conn === false) {
            $ret = array(
              "data" => array("error" => "database connection error, please check your settings !"),
            } else {
            mysql_select_db($database_conn, $conn);
              * simple dispatcher. The $_REQUEST["method"] parameter selects the operation to execute.
              * must be one of the values findAll, insert, update, delete, Count
            // execute the necessary function, according to the operation code in the post variables
            switch (@$_REQUEST["method"]) {
              case "FindAll":
               $ret = findAll();
              break;
              case "Insert":
               $ret = insert();
              break;
              case "Update":
               $ret = update();
              break;
              case "Delete":
               $ret = delete();
              break;
              case "Count":
               $ret = rowCount();
              break;
            $serializer = new XmlSerializer();
            echo $serializer->serialize($ret);
            die();
            What I want to do is add a column called Download and then each row needs to have a Link to run a php script, with an id variable on the end so the php can genrate the TCPDF script and make a pdf file. I have a static HTMl based solution:
            http://www.mascotconstruction.com/orders/view.php
            I just need to figure out the correct syntax to put the link in so FLex will use it,
            • 3. Re: FLEX 3 PHP TCPDF QUESTION
              Thanks, this looks good, I have made a simple versio
              n that pulls from my db, however, I have an error when I include the link, what is the correct syntax
              to pull the link over:
              link to php:
              http://www.mascotconstruction.com/flex/mascot_orders-debug/vieworders.php
              PHP CODE:
              <?php
              $query = "SELECT * FROM SALLY_ORDERS";
              $result = mysql_query($query);
              while($row = mysql_fetch_array($result))
                echo "<user><date>".$row['date']."</date><orderid>".$row['id']."</orderid><storeid>".$row['sto re_id']."</storeid><routeid>".$row['route_id'].'</routeid><download><a href="http://www.mascotconstruction.com/orders/getorder.php?id='.$row['id'].'" //Download page in this case uses the primary key of the row to select the data to create the pdf.>Download</a></download></user>\n';
              It works on the php page but when I try to launch the swf it gets:
              [RPC Fault faultString="Error #1090: XML parser failure: element is malformed." faultCode="Client.CouldNotDecode" faultDetail="null"]
              at mx.rpc.http::HTTPService/http://www.adobe.com/2006/flex/mx/internal::processResult()[C:\autobuild\3.2.0\frameworks\ projects\rpc\src\mx\rpc\http\HTTPService.as:851]
              at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()[C:\autobuild\3.2.0\frameworks\ projects\rpc\src\mx\rpc\AbstractInvoker.as:188]
              at mx.rpc::Responder/result()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\Responde r.as:43]
              at mx.rpc::AsyncRequest/acknowledge()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\ AsyncRequest.as:74]
              at DirectHTTPMessageResponder/completeHandler()[C:\autobuild\3.2.0\frameworks\projects\rpc\s rc\mx\messaging\channels\DirectHTTPChannel.as:403]
              at flash.events::EventDispatcher/dispatchEventFunction()
              at flash.events::EventDispatcher/dispatchEvent()
              at flash.net::URLLoader/onComplete()
              MSML link:
              http://www.mascotconstruction.com/flex/mascot_orders-debug/sally.html
              CODE:
              <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" verticalAlign="middle" applicationComplete="init()" backgroundGradientColors="[#ffffff, #ffffff]">
              <mx:Script>
              <![CDATA[
              import mx.events.ResizeEvent;
              import mx.rpc.events.ResultEvent;
              import mx.controls.Alert;
              Bindable]
              public var date:int;
              Bindable]
              public var orderid:int;
              Bindable]
              public var storeid:int;
              Bindable]
              public var routeid:int;
              Bindable]
              public var techid:int;
              Bindable]
              public var download:String;
              Bindable]
              public var dataDump:String = "dataDump";
              private function init():void
              getUsers.send();
              private function getUsersResult(evt:ResultEvent):void
              userDG.dataProvider = evt.result.user;
              </mx:Script>
              <mx:HTTPService id="getUsers" url="vieworders.php" method="POST" result="getUsersResult(event)">
              <mx:request xmlns="">
              <data>{dataDump}</data>
              </mx:request>
              </mx:HTTPService>
              <mx:Panel
              title="Orders" width="600" height="300" layout="absolute" x="10">
              <mx:VBox x="0" y="0" width="596" height="260">
              <mx:DataGrid id="userDG" width="596" height="100%">
              <mx:columns>
              <mx:DataGridColumn headerText="Date" dataField="date"/>
              <mx:DataGridColumn headerText="Order ID" dataField="orderid"/>
              <mx:DataGridColumn headerText="Store ID" dataField="storeid"/>
              <mx:DataGridColumn headerText="Route ID" dataField="routeid"/>
              <mx:DataGridColumn headerText="Tech ID" dataField="techid"/>
              <mx:DataGridColumn headerText="Download" dataField="download"/>
              </mx:columns>
              </mx:DataGrid>
              </mx:VBox>
              </mx:Panel>
              </mx:Application>
              • 4. Re: FLEX 3 PHP TCPDF QUESTION
                from a quick glance, i think it's this that is throwing the error:
                  echo
                .$row['store_id']."</storeid><routeid>".$row['route_id'].'</routeid><download><a
                you're putting <a href> tags into the xml, which'll make it malformed.
                try
                  echo "<user><date>".$row['date']."</date><orderid>".$row['id']."</orderid><storeid>".$row['sto re_id']."</storeid><routeid>".$row['route_id']."</routeid><download>http://www.mascotconstruction.com/orders/getorder.php?id=".$row['id']."</download></user>\n';
                instead.
                • 5. Re: FLEX 3 PHP TCPDF QUESTION
                  Got it thanks for the helpful info. I used the link below to make a function that creates a link! And it works!!!
                  http://www.switchonthecode.com/tutorials/flex-datagrid-goodies-row-color-and-others
                  Your tutorials and code is pretty nifty, I will be checking out your other project Fo' sho;'!
                  Flex is pretty awesome!
