1 Reply Latest reply on Apr 14, 2010 8:29 PM by Bertrand G.
    ColumnSeries fill color change fails
    Bertrand G.
      I have a chart with column series that are populated dataprovider and for which the color is set in a separate CSS file.
      My software allows to dynamically change the CSS (compiled as SWF) and apply the changes.
      problem:
      - the first time the chart is drawn, the styles are applied
      - but if I change the style, without recreating a new graph, the bars disappear (but I can still see the tooltips). Then if I discard the graph and draw it again, then the style with the new color for the bars is correctly applied.
      More info:
      * CSS files, all with different colors, here is an example:
      mx|ColumnSeries{
           fills:#5B7A40, #5B7A40;
      I also tried to use the 'fill' property instead of 'fills'... same thing happen
      * styleSheet toggle function:
      public function toggleStyleSheet(styleSheetName:String):void {
           myStyleManager.unloadStyleDeclarations(currCSSName, false);
           currCSSName = styleSheetName;
           myStyleManager.loadStyleDeclarations(styleSheetName, true);
      So is there something I should in order for the change to take effect? It works with a CircleItemRenderer for plotChart, I don't know why it should be any different for this!!
      Any ideas?
