2 Replies Latest reply on Apr 15, 2010 1:34 AM by mvlele
    Question: Does Captivate Have an audio problem in Win 7?
    monsterjonno1955 Level 1
      I have just installed Captivate on my new Dell notebook computer. Recording sound, opening .wav or .mp3 files is impossible and gives me an "Unable to decode and import selected wav/mp3 file" message. Even the sound files in the libarary give me the same error message when I try to open them. Is this a problem of OS incompatability or something else?
        • 1. Re: Question: Does Captivate Have an audio problem in Win 7?
          Lilybiri MVP & Adobe Community Professional
          Hello,
          Are you talking about version 4 of Captivate? If so, did you install the update released in May 2009 (can be accessed using Help, Updates)? This solved some audio issues. I do use CP4 on a Win7 laptop but it is 32-bit. I heard on this forum that there are some issues with Win7 64-bit. You'll have to run CP4 as Administrator. Another workaround is using XP-compatibility mode.
          Lilybiri
          • 2. Re: Question: Does Captivate Have an audio problem in Win 7?
            mvlele Level 3
            Please try to register 'NSAudio.dll' file. This can be done using following steps -
            1. Close Adobe Captivate application.
            2. Open command prompt in administrator mode. This can be done by going to Start > Accessories > right click on 'command prompt' > run as adminsistrator'
            3. In command prompt, go to the Adobe Captivate installer folder. Generally it is located at <home dir>/Program Files/Adobe/Adobe Captivate 4/
            4. Enter the command - "regsvr32 NSAudio.dll". Hit ENTER
            5. Now enter the command "regsvr32 WaveEditCtrl.ocx". Hit ENTER
            You should get a message saying 'registration successful'. Please try to launch Captivate and execute your audio workflows.Hope this helps.
            Also please note that Adobe Captivate 4 is not officially supported on Win 7 but it works most of the times.
            Regards,
            Mukul
