2 Replies Latest reply on Apr 15, 2010 4:51 AM by Alex-Wright
    SWFLoader issue
    Alex-Wright Level 1
      When loading and external .swf file, I get the following error:
      URIError: Error #1052: Invalid URI passed to decodeURI function.
          at global/decodeURI()
          at mx.controls::SWFLoader/OSToPlayerURI()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\ controls\SWFLoader.as:1938]
          ...etc....
      First and foremost - what does this mean exactly?
      Secondly, why would I be seeing this error in Flex 4 now, when the code used to work with Flex 3.5?
        Alex.
        • 1. Re: SWFLoader issue
          CoreyRLucier Adobe Employee
          This method is new to 4.x I believe.
          The comments for OSToPlayerURI:
          • Currently (FP 10.x) the ActiveX player (Explorer on Windows) does not
          • handle encoded URIs containing UTF-8 on the local filesystem, but
          • it does handle those same URIs unencoded. The plug-in requires
          • encoded URIs.
          Can you send along the source URL you were using to load?
          -C
          • 2. Re: SWFLoader issue
            Alex-Wright Level 1
            Hi, thanks for your reply.
            Sure, the URL refers to an external swf file and the parameters sent to it, an example of which would be:
            http://<IP address and file structure omitted>/awv.swf
            The parameters passed to it look like this:
            ?awvByteHandlerPath=<IP address omitted>
            &awvImagePath=<Image path omitted>
            &awvWidth=1133&awvHeight=687
            &awvX=-0.34302108671969433
            &awvY=-0.39048279531074837
            &awvZoom=23%
            &awvToolbar=1
            &awvMenubar=0
            &awvNavWindow=0
            &awvNavWidth=150
            &awvNavHeight=100
            &awvSlider=1
            These are all comined together to make the url string. The paths are omitted for security.
            It's basically passing a very large image (~80000 x 60000 px) to the swf with specific parameters. The swf itself is a proprietary application and behaves much like zoomify.
            Not too clear on how to send the URIs unencoded. How would I do that?
            Thanks again,
              Alex.
