6 Replies Latest reply on Sep 17, 2007 8:16 AM by Bob Saggot
    deleting rows from grid --- need help
    lalson
      Hi All ,
      Need some help in deleting selected rows from grid. I am able to add rows to Grid. But unable to delete selected rows from Grid. Even user checks multiple rows its deleting only one row at a time. And one more problem I am facing is its not retaining the values entered by user if I add / delete rows to Grid.
      Here is the code what I tried for deleting and adding rows to Grid
      public function addOtherIncome():void
      incomeData.addItem({Charterer:'',incomeDesc:'',incomeAmt:''});
      public function deleteIncome():void
      //Alert.show("Inside Delete Item" + checkIncome.length );
      for(var j:Number=0;j<checkIncome.length;j++)
      Alert.show("inside of for "+ checkIncome[j].selected);
      if(checkIncome[j].selected==true)
      incomeGridRow.height = 0;
      incomeData.removeItemAt(j);
      incomeData ----- name of the data provider
      checkIncome ----- name of the checkbox
      incomeGridRow ----- name of the gridrow
      Anybody help me to solve these issues. I tried a lot to solve these issues. Thanx in advance
      Thanks & Regards,
      Lalitha
        • 1. Re: deleting rows from grid --- need help
          Level 7
          Just Try
          if (incomeDate.lenght > 0)
          incomeData.removeItemAt(dataGridName.selectedIndex);
          I hope this help.
          Rgds
          JFB
          "lalson" <webforumsuser@macromedia.com> wrote in message
          news:fc8mrn$f5g$1@forums.macromedia.com...
          > Hi All ,
          > add
          > checks
          > am
          > rows
          > to Grid.
          > Thanks & Regards,
          > Lalitha
          • 2. Re: deleting rows from grid --- need help
            lalson Level 1
            Thanks for ur reply. I have a clarification here in the line " incomeData.removeItemAt(dataGridName.selectedIndex) " . I am using grid and not datagrid in my code. The selectedIndex property is not present for grid .Inside <mx:Grid> i am having a <mx:Repeater id="repIncome" dataProvider="incomeData"> and inside repeater i am having gridRow.Here incomeData is an ArrayCollection.
            Thanks & Regards,
            Lalitha
            • 3. Re: deleting rows from grid --- need help
              Level 7
              Ups.. sorry, never use grid
              Check this sample.
              http://www.cflex.net/showFileDetails.cfm?ObjectID=687
              Rgds
              JFB
              news:fcaotp$r2p$1@forums.macromedia.com...
              > Hi,
              > and not
              > Thanks & Regards,
              > Lalitha
              • 4. deleting rows from grid --- need help
                lalson Level 1
                Hi JFB,
                Ya I tried what u advised me to solve the issue. I used DataGrid instead of Grid. But still I am facing following problems.
                1. how to relate delete method with check boxes in datagrid. I mean in my application I have checkbox as one column. User can delete multiple rows bys checking checkboxes. I have to delete those rows. By doing this one I am facing the problems.
                2. How to select mutiple rows in DataGrid .
                3.. Its not deleting multiple rows at a time . I used the following code to delete mutiple rows.
                public function deleteOtherIncome():void {
                for(var j:Number=0;j<initDG.length;j++)
                if(initDG.length>0){
                initDG.removeItemAt(incomeGrid.selectedIndex);
                But its behaving strangly mean its not deleting selected rows , its deleting different rows irrespective of selected rows .
                Thanks & Regards,
                Lalitha
                • 5. Re: deleting rows from grid --- need help
                  Level 7
                  I'm afraid that you can't even select multiple rows... you need to delete
                  one row at the time.
                  Rgds
                  JFB
                  news:fclq4q$6u3$1@forums.macromedia.com...
                  > Hi JFB,
                  > of
                  > 1. Its not deleting multiple rows at a time . I used the following code
                  > to
                  > Alert.show("Selected Length" + selectedDG.length);
                  > //Alert.show("j -----> "+incomeGrid.selectedIndex);
                  > //incomeGrid.height = incomeGrid.height - 22;
                  • 6. deleting rows from grid --- need help
                    Bob Saggot Level 1
                    You should be able to delete multiple rows at a time, just remove it from whatever the dataprovider is.. a array or arraycollection, and it should automatically update.
                    try this instead, i believe whats going on is once you delete from the datagrid, the selected index is different, so once you are deleting item number 1, it collaspes and item number 1 IS what item number 2 was...
                    the fix would be something like...
                    private function selectedDataGridItems():void
                    for(how many selected items)
                    array .push(datagrid.selecteditemnum(i))//populate it with all the selected datagrid items // incorrect code you would need to look it up
                    array.sort(descending); //gets the highest number first
                    for(array.length,i++)
                    deleteitem(array );
                    deleteitem(num:number)
                    dataproviderforDataGrid.removeitemat(num);
