0 Replies Latest reply on Apr 15, 2010 8:57 AM by Paul Reilly
    [svn:fx-trunk] 15439: * Take two with merging revisions 14005 and 14621 from sherlock to
    Paul Reilly Level 1
      Revision: 15439
      Revision: 15439
      Author:   preilly@adobe.com
      Date:     2010-04-15 08:57:32 -0700 (Thu, 15 Apr 2010)
      Log Message:
      • Take two with merging revisions 14005 and 14621 from sherlock to
        trunk.  The previous attempt, revision 15108, caused SDK-26068, so
        it was reverted by revision 15145.  SDK-26068 should be fixed now by
        this revision.  Also, SDK-26045 turned out to be a bug in the
        performance testsuite harness, so this revision shouldn't cause any
        increase in inactive memory usage.
      QE notes:
      Doc notes:
      Bugs: SDK-26068, SDK-26045
      Reviewer: originally reviewed by Tom H. and Pete F.
      Tests run: full trunk cyclone
      Is noteworthy for integration: Yes.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-26068
          http://bugs.adobe.com/jira/browse/SDK-26045
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/InMemoryFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/VirtualZipFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/MovieTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDirectoryArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDynamicArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLazyReadArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLibrary.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
