1 Reply Latest reply on Apr 15, 2010 6:09 PM by John Waller
    IE css issue
    valf Level 1
      Hi all!
      I have a pb with a css not rendering the way it should be in explorer . If you go to http://elhoster.com/shuttle , the page should be aligned in the center but it is not while it does in Firefox... I can't see what css is bugging . The alignement is set correctly but there probably is some conflict somewhere and I can't spot it , maybe someone will spot it straiught away ...
      Please let me know if you need anything that could help . Many thanks in advance
        • 1. Re: IE css issue
          John Waller Adobe Community Professional & MVP
          The code in that page is unfortunately badly broken.
          e.g. multiple <html>, <body> tags etc.
          Looks like a complete DW template page (from <html> to </html>) has been cut-and-paste into another complete page. I suspect the code lines 25 to 1139 are the real page and the rest, above and below, should be deleted.
          Suggest you fix the page code and validate it here http://validator.w3.org/ before tweaking the finer detail.
