1 Reply Latest reply on Apr 15, 2010 3:30 PM by peteandrus
    am i handling this RemoteObject correctly?
    peteandrus Level 1
      my handler function is not catching a ResultEvent correctly the way it should. Here is the code:
      public class PagedDataGrid_Controller
              //var recipIDFetcher:RemoteObject;
              private var model:PagedDataGrid_Model;
              private var recipIDFetcher:RemoteObject;
              public function PagedDataGrid_Controller(IN:PagedDataGrid_Model)
                  recipIDFetcher = new RemoteObject("recipReferenceQuery");
                  recipIDFetcher.searchResults1.addEventListener(ResultEvent.RESULT,dealWithRecipQueryResul t);
                  model = IN;
              public function dealWithRecipQueryResult(event:ResultEvent):void
                  model.ids = event.result as ArrayCollection;
              public function dealWithRecipQuery():void{
                  recipIDFetcher.searchResults1();
      my remote object has a method called searchResults1. i am wondering if i should change the line:
      recipIDFetcher.searchResults1.addEventListener(ResultEvent.RESULT,dealWithRecipQueryResult );
      to
      recipIDFetcher.addEventListener(ResultEvent.RESULT,dealWithRecipQueryResult);
      can anyone spot any problems here? i know this object works right because i've used it before. thanks!
        • 1. Re: am i handling this RemoteObject correctly?
          peteandrus Level 1
          nevermind, i figured it out. i wasn't catching the fault event, which of course is what was happening! thanks
          new code for posterity's sake:
                      recipIDFetcher.addEventListener(FaultEvent.FAULT,dealWithRecipQueryFault);
                      model = IN;
                  public function dealWithRecipQueryFault(event:FaultEvent):void
                      var fault:String = event.message.toString();
