1 Reply Latest reply on Apr 16, 2010 6:31 AM by David_F57
    Getting jpgs from AIR.fileApplicationStorage
    richtextformat Level 1
      this is driving me crazy
      putting loaded jpgs into the directory is simple and works well:
      public function setImage (imageName:String, image:Bitmap):void
          var encoder:JPEGEncoder = new JPEGEncoder(80);
          var byteArray:ByteArray = encoder.encode(image.bitmapData);
          var file:File = File.applicationStorageDirectory.resolvePath(imageName);
          var fileStream:FileStream = new FileStream();
          try {
              fileStream.open(file, FileMode.WRITE);
              fileStream.writeBytes(byteArray);
              fileStream.close();
          } catch (e:Error){
              trace('setImage ERROR:', e.message);
      getting them out again seems nigh on impossible:
      public function getImage (imageName:String):Bitmap
          var bytes:ByteArray = new ByteArray();
          trace('getImage BEF', bytes.bytesAvailable);
          var stream:FileStream = new FileStream();
          stream.open(file, FileMode.READ);
          stream.readBytes(bytes, 0, stream.bytesAvailable);
          stream.close();
          trace('getImage AFT', bytes.bytesAvailable);
          var loader:Loader = new Loader();
          loader.addEventListener(Event.COMPLETE, onComplete)
          loader.addEventListener(IOErrorEvent.IO_ERROR, onError);
          loader.loadBytes(bytes);
          var bitmapData:BitmapData = new BitmapData(175,175);
          bitmapData.draw(loader);
          var bitmap:Bitmap = new Bitmap(bitmapData);
          return bitmap;
          trace('getImage -----------------------');
      private function onComplete (event:Event):void
          trace('onComplete', event.target);
      private function onError (event:IOError):void
          trace('onError', event.message);
      running two stored images through this retrieval method gives the following trace output:
      getImage BEF, 0
      getImage AFT, 6760
      getImage
      getImage BEF, 0
      getImage AFT, 7039
      getImage
      so clearly the bytearray data is being loaded, but the onComplete and onError methods are NEVER fired and the returned Bitmap is just a white square. the files in question definitely are jpgs.
      what am I doing wrong?
