1 Reply Latest reply on Oct 9, 2006 6:55 AM by Newsgroup_User
    help needed with for loop logic?
    BuzzF
      Hi guys
      I'm having real trouble trying to get my head around the logic of a loop.
      basically I want to conduct a for loop where a variable has the value of a function call on its previous iteration. I know how many iterations i need to do.
      here is an example of what i want to do - (without using a for loop)
      variable1 = joesFunction(content);
      variable2 = joesFunction(variable1);
      variable3 = joesFunction(variable2);
      variable4 = joesFunction(variable3);
      and so on...
      I don't know how to make my for loop work!
      i've currently got:
      for (i=1; i<=totalIterations; i++) {
      _root["variable"+i+1] = joesFunction(eval("variable"+i));
      Can anyone point me in the right direction as to how to write a functioning for loop for this?
      Thanks for all your responses, they're helping a lot!
        • 1. Re: help needed with for loop logic?
          Level 7
          Hi!
          I recommend you use array to solve this problem. Here is an example code:
          content = 100;
          totalIterations = 5;
          function joesFunction(num:Number):Number {
          return num*2;
          var myVar:Array = new Array();
          myVar[0] = joesFunction(content);
          myVar = joesFunction(myVar[i-1]);
          trace(myVar);
          /Jensen/
          "BuzzF" <webforumsuser@macromedia.com> wrote in message
          news:egdac0$cg8$1@forums.macromedia.com...
          > Hi guys
          > to
          > do.
          > and so on...
          > i've currently got:
          > functioning
          > for loop for this?
