13 Replies Latest reply on Apr 18, 2010 1:37 AM by Jochem van Dieten
    Looping array frequently goes out of bounds
    kenji776 Level 1
      Hello all,
      I have a process which pulls information from a database, converts the data into an array, in which every element contains a structure with two keys (name and value). That information is then processed and returned to another system. The problem is, often times when looping over the array that contains the structures, the loop will go out of bounds and attempt to access array elements that do not exist. Further more, sometimes either the "name" or "value" key will be blank. I currently am unaware of any pattern to this behavior.
      <!--- Get all the data for the given PID (an ID number associated to a contact) --->
      <cfquery name="Login" datasource="WebServer" maxrows="1">
           Select *
           From SFContactSync
           Where PID = <cfqueryparam cfsqltype="cf_sql_integer" value="#form.PID#">
      </cfquery>
      <!--- Assign All the information from the login query into variables we can return --->
      <cfloop list="#Login.columnList#" index="columnName">
           <cfset counter = counter + 1>
           <cfset VariablesObject[counter] = structnew()>
           <cfset VariablesObject[counter]["Name"] = columnName>
           <cfset VariablesObject[counter]["Value"] = #Login[columnName][1]#>
      </cfloop>
      <!--- Create one more entry that contains the full name of the person --->
      <cfset VariablesObject[counter]["Name"] = "FullName">
      <cfset VariablesObject[counter]["Value"] = "#Login.Firstname# #Login.Lastname#">
      <!--- Set the next page to go to --->
      <cfset nextPage = "/15">
      <cfset ReturnObject = server.IVRUtilities.printMessage(nextPage,VariablesObject)>
      <!--- Function for creating return AngelXML --->
      <cffunction name="printMessage" access="remote" hint="Print a message for the Angel IVR System">
           <cfargument name="address" default="none" type="string">
           <!--- This is an array of structures, with keys "name" and "value" --->
           <!--- EX variables[1].Name = Gender --->
           <!--- EX variables[1].Value = Male --->
           <cfargument name="variablesToInclude" default="" type="any" required="no">
           <cfargument name="promptText" default="." type="string" required="no">
           <cfoutput>
                <cfsavecontent variable="ReturnMessage">
                     <ANGELXML>
                          <MESSAGE>
                               <PLAY>
                                    <PROMPT type="text">
                                         <cfoutput>#arguments.promptText#</cfoutput>
                                    </PROMPT>
                               </PLAY>
                               <GOTO destination="#listlast(address)#" />
                          </MESSAGE>
                          <cfif IsArray(arguments.variablesToInclude)>
                               <VARIABLES>
                                    <cftry>
                                         <cfloop from="1" to="#arraylen(arguments.variablesToInclude)#" index="i">
                                              <cfif structkeyexists(arguments.variablesToInclude[i],'Name') and  structkeyexists(arguments.variablesToInclude[i],'value')>
                                                   <VAR name="#ucase(arguments.variablesToInclude[i]['Name'])#" value="#ucase(arguments.variablesToInclude[i]['Value'])#" />
                                              </cfif>
                                         </cfloop>
                                         <cfcatch type="any">
                                              <cfset ErrorData = structnew()>
                                              <cfset ErrorData.Error = cfcatch>
                                              <cfset ErrorData.Arguments = arguments>
                                              <cfset ErrorData.form = form>
                                              <cfset SendError = server.utilities.SendErrorReport(ErrorData)>
                                         </cfcatch>
                                    </cftry>
                               </VARIABLES>
                          </cfif>
                          </ANGELXML>
                </cfsavecontent>
           </cfoutput>
           <cfreturn ReturnMessage>
      </cffunction>
      For example, I have an error sitting in my inbox now that says
      The element at position 25 cannot be found.
      But viewing the dump of the included elements shows only 24 elements. For some reason the loop here
           </cfif>
      </cfloop>
      does seem to stop at the right point. The cfif statment would error, becuase it tries to evaluate an array element that does not exist. Whats up with that?
      I was thinking of adding more checking to see if the array element exsists, but I am hesitant to add any more "checking" code than I really need beucase this is a somewhat high performance critical app. Any thoughts or comments are welcome.
        • 1. Re: Looping array frequently goes out of bounds
          Dan Bracuk Level 5
          Look's like a case of overengineering.  What do you think you can accomplish with an array of structures that you can't accomplish with the initial query?
          • 2. Re: Looping array frequently goes out of bounds
            kenji776 Level 1
            Mostly the fact that I wanted that function to be reuseable, there are several occasions where I need to create the AngelXML data, and I don't know ahead of time what kind of data I am going to be passing, if any. The array of structures gives me the flexibility to pass it any kind of data. Sometimes i need to populate it from a query, other times I pass it just a hard coded ID.
            • 3. Re: Looping array frequently goes out of bounds
              yui8979 Level 1
              I can't see anything wrong with your code. What do you get when you dump out
              the array length of that variable, at each iteration, from inside the
              function's loop?
              • 4. Re: Looping array frequently goes out of bounds
                kenji776 Level 1
                I'll try putting in some more debugging. When I dump out all the arguments, I clearly see there are 24 array elements, but it attempts to loop to 25. You're thinking maybe somehow the data is being affected in the loop?
                Here is a sample dump
                An error has occurred in a Cold Fusion page template. All the information available is included below. Please note that not all included data may be relevent, but is included for completness sake.
                Error Info
                struct
                ARGUMENTS
                struct
                ADDRESS
                /7
                PROMPTTEXT
                VARIABLESTOINCLUDE
                array
                1
                struct
                Name
                ACCOUNTID
                Value
                x
                2
                struct
                Name
                ACTIVATED
                Value
                [empty         string]
                3
                struct
                Name
                AGE
                Value
                41
                4
                struct
                Name
                BIRTHDATE
                Value
                1969-03-11
                5
                struct
                Name
                CONTACTDUPECHECKFIELD
                Value
                x
                6
                struct
                Name
                CONTACTFINGERPRINT
                Value
                [empty         string]
                7
                struct
                Name
                CONTACTID
                Value
                x
                8
                struct
                Name
                EMAIL
                Value
                x
                9
                struct
                Name
                EMAILSOPENED
                Value
                1
                10
                struct
                Name
                EMAILSSENT
                Value
                6
                11
                struct
                Name
                FIRSTNAME
                Value
                x
                12
                struct
                Name
                FULLNAME
                Value
                x
                13
                struct
                Name
                GENDER
                Value
                Male
                14
                struct
                Name
                IVRCALLSANSWERED
                Value
                0
                15
                struct
                Name
                IVRCALLSMADE
                Value
                1
                16
                struct
                Name
                LASTMODIFIED
                Value
                2010-02-22         21:42:28.607
                17
                struct
                Name
                LASTNAME
                Value
                x
                18
                struct
                Name
                LASTPUSH
                Value
                2010-04-02         03:02:33.65
                19
                struct
                Name
                PHONE
                Value
                x
                20
                struct
                Name
                PID
                Value
                x
                21
                struct
                Name
                PIN
                Value
                x
                22
                struct
                Name
                PORTALLOGINS
                Value
                1
                23
                struct
                Name
                SYNCEDTOSF
                Value
                0
                24
                struct
                Name
                FullName
                Value
                x
                ERROR
                struct
                Detail
                [empty     string]
                ErrNumber
                0
                Message
                StackTrace
                coldfusion.runtime.CfJspPage$ArrayBoundException:     The element at position 25 cannot be found. at     coldfusion.runtime.CfJspPage.ArrayGetAt(CfJspPage.java:869) at     coldfusion.runtime.CfJspPage._arrayGetAt(CfJspPage.java:930) at     coldfusion.runtime.CfJspPage._arrayGetAt(CfJspPage.java:925) at     cfutilities2ecfc868057140$funcPRINTMESSAGE.runFunction(C:\Website\Components\IVR\utilitie s.cfc:130)     at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:418) at     coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:324)     at     coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:59)     at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:277) at     coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:192) at     coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:448) at     coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:308) at     coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2272) at     cfAuthenticate2ecfm747801116.runPage(C:\Website\Portal\IVR\Authenticate.cfm:85)     at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196) at     coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370) at     coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65) at     coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279) at     coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)     at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at     coldfusion.filter.PathFilter.invoke(PathFilter.java:86) at     coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70) at     coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)     at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at     coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)     at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at     coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:126)     at coldfusion.CfmServlet.service(CfmServlet.java:175) at     coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at     jrun.servlet.FilterChain.doFilter(FilterChain.java:86) at     coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )     at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)     at jrun.servlet.FilterChain.doFilter(FilterChain.java:94) at     jrun.servlet.FilterChain.service(FilterChain.java:101) at     jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106) at     jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at     jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)     at     jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)     at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)     at     jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)     at     jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)     at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)     at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
                TagContext
                array
                1
                struct
                COLUMN
                0
                ID
                LINE
                130
                RAW_TRACE
                TEMPLATE
                C:\Website\Components\IVR\utilities.cfc
                TYPE
                CFML
                2
                struct
                COLUMN
                0
                ID
                CF_TEMPLATEPROXY
                LINE
                85
                RAW_TRACE
                TEMPLATE
                TYPE
                CFML
                Type
                Expression
                aDimension
                -1
                aIndex
                25
                FORM
                struct
                AUTHTOKEN
                [empty     string]
                CALLDIRECTION
                Outbound
                CALLGUID
                x
                DEBUG
                false
                DISCONNECTPAGE
                /140
                FAILPAGE
                /155
                FIELDNAMES
                CALLGUID,DISCONNECTPAGE,SUBSCRIBERID,PID,LOGINPAGE,NEXTPAGE,FAILPAGE,PIN,CALLDIRECTION
                LOGINPAGE
                /4
                NAVCODE
                [empty     string]
                NEXTPAGE
                /7
                PID
                x
                PIN
                [empty     string]
                SUBSCRIBERID
                x
                FromEmail
                x
                Subject
                Error   in template
                x
                Message was edited by Jochem van Dieten to remove privae information.
                • 5. Re: Looping array frequently goes out of bounds
                  kenji776 Level 1
                  Wow, it gets weirder. I just got an error report, it tried to access element 17, even though there was only one argument. Am I maybe dealing with variable scope issue here?
                  Error Info
                  struct
                  ARGUMENTS
                  struct
                  ADDRESS
                  /140
                  PROMPTTEXT
                  VARIABLESTOINCLUDE
                  array
                  1
                  struct
                  NAME
                  ID
                  VALUE
                  081FAFF5-C299-2427-53D7A6720B424A41
                  ERROR
                  struct
                  Detail
                  [empty     string]
                  ErrNumber
                  0
                  Message
                  The     element at position 17 cannot be found.
                  StackTrace
                  coldfusion.runtime.CfJspPage$ArrayBoundException:     The element at position 17 cannot be found. at     coldfusion.runtime.CfJspPage.ArrayGetAt(CfJspPage.java:869) at     coldfusion.runtime.CfJspPage._arrayGetAt(CfJspPage.java:930) at     coldfusion.runtime.CfJspPage._arrayGetAt(CfJspPage.java:925) at     cfutilities2ecfc868057140$funcPRINTMESSAGE.runFunction(C:\Website\Components\IVR\utilitie s.cfc:130)     at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:418) at     coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:324)     at     coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:59)     at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:277) at     coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:192) at     coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:448) at     coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:308) at     coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2272) at     cfLogcallNew2ecfm465243765.runPage(C:\Website\Portal\IVR\LogcallNew.cfm:46)     at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196) at     coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370) at     coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65) at     coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279) at     coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)     at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)     at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70) at     coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)     at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at     coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46) at     coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at     coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at     coldfusion.CfmServlet.service(CfmServlet.java:175) at     coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at     jrun.servlet.FilterChain.doFilter(FilterChain.java:86) at     coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )     at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)     at jrun.servlet.FilterChain.doFilter(FilterChain.java:94) at     jrun.servlet.FilterChain.service(FilterChain.java:101) at     jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106) at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)     at     jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)     at     jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)     at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)     at     jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)     at     jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)     at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)     at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
                  TagContext
                  array
                  1
                  struct
                  COLUMN
                  0
                  ID
                  LINE
                  130
                  RAW_TRACE
                  TEMPLATE
                  TYPE
                  CFML
                  2
                  struct
                  COLUMN
                  0
                  ID
                  CF_TEMPLATEPROXY
                  LINE
                  46
                  RAW_TRACE
                  TEMPLATE
                  TYPE
                  CFML
                  Type
                  Expression
                  aDimension
                  -1
                  aIndex
                  17
                  FORM
                  struct
                  CONTACTATTEMPT
                  1
                  DATESTAMP
                  {ts     '2010-04-16 14:36:54'}
                  ID
                  Subject
                  Error   in template
                  • 6. Re: Looping array frequently goes out of bounds
                    yui8979 Level 1
                    You might be on to something there ... your function is Server scoped? you
                    need to var scope the variables in your cfffunction for them to be trully
                    local
                    <cfset var x = "">
                    <cfset var ReturnMessage = "">
                    etc.
                    • 7. Re: Looping array frequently goes out of bounds
                      kenji776 Level 1
                      The only variables I use are the ones passed into the arguments, and the loop counter defined as i. if I create i as a local variable and set it to 0 perhaps that will clear the issues up.
                      • 8. Re: Looping array frequently goes out of bounds
                        Adam Cameron. Level 5
                        You should always VAR all variables used in functions, unless you specifically want them to be shared across method calls.
                        It looks to me like you have your CFC instantiated in some shared scope, and - given you are not VARing any variables - all requests calling those methods are sharing those variables.  This will yield "unexpected" results.
                        Adam
                        • 9. Re: Looping array frequently goes out of bounds
                          -==cfSearching==- Level 4
                          I suspect Adam is correct about the missing var scoping.
                          BTW: The account and pin numbers you posted ... are they for anything important?
                          • 10. Re: Looping array frequently goes out of bounds
                            kenji776 Level 1
                            Seems you guys were probably right about the var scoping being the issue. For some reason I had it in my head that variables created within loops where local to that loop or something. Doesn't make much sense in retrospect. Creating the variable beforehand, and setting it to 0 seems to has resolved the issue.
                            That extra info in the dump isn't anything terribly important (you can only get into some small website that doesn't have any really useful info) but I'll remove it anyway. Thanks for the heads up.
                            Edit: Damn, for some reason I cannot modify my above posts. Hey mods, if you see this, can you kill those post above witht he dump info in there please?
                            • 11. Re: Looping array frequently goes out of bounds
                              I assume you mean you "var" scoped the variable? Be sure to do the same for all of the function-local variables (ie ones you do not want shared).
                              I do not think this forum has that kind of moderator.
                              Always  scrub stuff before posting. Most forums are routinely archived by search engines  and other sites. So once you post something, the original is out there (on one site or another) ... most likely  permanently.
                              • 12. Re: Looping array frequently goes out of bounds
                                kenji776 Level 1
                                Yeah I set it as a var. I normally do, just I didn't really think I had to for a for that variable, figured the loop would
                                re-init it at 0, but that was a dumb assumption. Thats weird I can't edit posts, and there are no mods. Sure I made a mistake, but the fact
                                that there is no way to correct it is fairly stupid.
                                • 13. Re: Looping array frequently goes out of bounds
                                  Jochem van Dieten Level 4
                                  As son as somebody has replied to a message the message can not be changed anymore, except by a moderator. If you need something fixed in a post, click the "Report abuse" link and explain what needs to be done.
