1 Reply Latest reply on Apr 16, 2010 12:26 PM by [Jongware]
    InDesign CS4 js Zero point
    Yuliaart Level 1
      InDesign has 3 zero points: two in the upper left corner for x and y and second x in upper right corner. When I rotated graphic that is bigger than the artbord, it ocasinally gets confused which x zero to use and rotates the graphic of the artbord. Is there a way to tell it which zero point to use.
      Thank you very much for your help.
      Yulia
        • 1. Re: InDesign CS4 js Zero point
          Switch from page oriented rulers to spread oriented:
          app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.SPREAD_ORIGIN;
          Alternatively, you could try the third option (Spine) -- zero at the center and counting down to the left and up to the right. That's easy to handle mirrored layouts with.
