0 Replies Latest reply on Apr 16, 2010 2:11 PM by stuttsdc
    cfgrid update and insert issue *help!!*
      I have a form that contains a cfgrid named idGrid (using CF9).
      Contains  four columns: Autonum (for now, the pk), CR_ID (fk), ID, and IDType.
      These  come from tblIDs in my db.
      The grid is editable but not the  Autonum or CR_ID fields (select="no").
      I am using code straight  from the Adobe help:
      http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859461172e0811cbec22c24 -7acf.html
      If  I try to edit the existing records in this grid, it posts back values  into the wrong columns!  It puts the CR_ID into tblIDs.ID and the ID  into tblIDs.IDType.
      If I try to insert a new record and then post  back the changes, I get an error:
      Element IDGGRID.ROWSTATUS.ACTION  is undefined in a Java object of type class [Ljava.lang.String;  referenced as ''
      I believe this is b/c fields in the new  record are null.  Autonum and CR_ID would likely be null but the user  might also just not enter anything.
      Major problem and I don't know  how to get around it.
      Please help!
      <cfquery name="get_IDs" datasource="bridges">
      SELECT tblIDs.Autonum, tblIDs.CR_ID, tblIDs.ID, tblIDs.IDType
      FROM tblIDs
      WHERE tblIDs.CR_ID = '#CFGRIDKEY#'
              title="Related IDs"
              width="250" rowheaderalign="left"
              autowidth="false" griddataalign="left" gridlines="yes" colheaderalign="left"
              selectmode="edit" insert="yes" insertbutton="Insert New ID" enabled="yes" visible="yes"
            <cfgridcolumn name="Autonum" display="no" select="no"/>
            <cfgridcolumn name="CR_ID" display="no" select="no"/>
            <cfgridcolumn name="ID" header="ID" />
            <cfgridcolumn name="IDType" header="ID Source" values="#r_idType#" valuesdisplay="#r_idType#" valuesdelimiter=","/>
      form posts to:
      <cfloop index = "counter" from = "1" to =
                  The row action for #counter# is:
      [b]<!-- Here, if updating and not inserting, it'll give back results like: The row action for 1 is: 11093 11093 {666666666666JUNKME} onceagain.  It's showing the Autonum field twice!! -->[/b]
              <cfif Form.idGrid.rowstatus.action[counter] is "U">
                  <cfquery name="UpdateIDTable"
                      UPDATE tblIDs
                                  CFSQLType="CF_SQL_VARCHAR" >
                      WHERE Autonum=<cfqueryparam
              <cfelseif Form.idGgrid.rowstatus.action[counter] is "I">
                  <cfquery name="InsertNewID"
                      INSERT into tblIDs (CR_ID, ID, IDType)
                      VALUES (<cfqueryparam
                          value="#Form.i_cr_id#"  [i](id taken from elsewhere)[/i]
                              <cfqueryparam value="#Form.idGrid.ID[counter]#"
                              <cfqueryparam value="#Form.idGrid.IDType[counter]#"
      ALSO... same things happens if I just use cfgridupdate:
      <cfgridupdate grid = "idGrid" dataSource = "bridges" Keyonly="true"
              tableName = "tblIDs">
