5 Replies Latest reply on Apr 17, 2010 10:11 AM by David_F57
    3 columned list
    iamcootis Level 1
      I have a list with a fixed area that whose dataProvider is a ArrayCollection of one-word strings. My client wants the data to appear in 3 rows, fitting all words into the area instead of using a scroll bar.
      Any ideas on the best way to accomplish this? I've thought about taking the first 3 words and putting them in an HBOX, but that doesn't sound like the best solution to me.
        • 1. Re: 3 columned list
          David_F57 Level 5
          hi you talk about rows and columns, do you want a tiled list ?, do you want snaked text or left to right
          snake
          1 4 7
          2 5 8
          3 6 9
          left to right
          1 2 3
          4 5 6
          7 8 9
          it is easier to help one the problem is explained better or a sample of what you are trying to do is given.
          David.
          • 2. Re: 3 columned list
            iamcootis-nQaZl5
            I'm not sure if I want a tiledList. I have never used one, I want the text to be snaked. Will a tiledlist do this for me?
            • 3. Re: 3 columned list
              David_F57 Level 5
              hi,
              Not sure if you are using flexbuilder or flashbuilder, the following would do what you want in flashbuilder it uses a tiled list with data by column (snaking)
              <s:List id="list"
              itemRenderer="spark.skins.spark.DefaultComplexItemRenderer"
              horizontalCenter="0"
              verticalCenter="0">
              <s:layout>
              <s:TileLayout requestedColumnCount="3" requestedRowCount="3"
                horizontalGap="2" verticalGap="2" orientation="columns"
              horizontalAlign="center" />
              </s:layout>
              <s:dataProvider>
              <s:ArrayList>
              <s:Label text="first"/>
              <s:Label text="second"/>
              <s:Label text="third"/>
              <s:Label text="fourth"/>
              <s:Label text="fifth"/>
              <s:Label text="six"/>
              <s:Label text="seventh"/>
              <s:Label text="eigth"/>
              <s:Label text="nineth"/>
              </s:ArrayList>
              </s:dataProvider>
              </s:List>
              • 4. Re: 3 columned list
                iamcootis-nQaZl5 Level 1
                Hey Thanks, that's not the exact syntax for Flexbuilder but it's enough for me to understand how to do it now.
                • 5. Re: 3 columned list
                  David_F57 Level 5
                  flex 3 syntax
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" minWidth="955" minHeight="600">
                  <mx:Script>
                  <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable] private var arr:ArrayCollection = new ArrayCollection(["1","2","3","4","5","6","7","8","9"]);
                  </mx:Script>
                  <mx:TileList x="249" y="131" direction="vertical" columnCount="3" rowCount="3" dataProvider="{arr}"></mx:TileList>
                  </mx:Application>
