0 Replies Latest reply on Apr 16, 2010 3:08 PM by Jason Szeto
    [svn:fx-trunk] 15522: ComboBox, DropDownList and PopUpAnchor bug fixes
    Jason Szeto Level 3
      Revision: 15522
      Revision: 15522
      Author:   jszeto@adobe.com
      Date:     2010-04-16 15:08:12 -0700 (Fri, 16 Apr 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-25764 - ComboBox will not display first item in dataProvider when dropdown is open
      The first item of the dataProvider was the object "Zero". This returns false in an equality check, so I changed the check to compare to undefiend
      http://bugs.adobe.com/jira/browse/SDK-25765 - ComboBox does not commit item when closed if Enter key is pressed
      Pressing Enter was actually clearing the selection. Fixed ComboBox.applySelection to only commit if the proposed selection is a custom string or if the dropdown is open
      http://bugs.adobe.com/jira/browse/SDK-25432 - Spark DropDownList throws RTE when trying to change data provider and open dropdown and use mouse wheel
      Added null check
      http://bugs.adobe.com/jira/browse/SDK-25132 - Odd rendering of pop up when using PopUpAnchor w/ popUpPosition == center
      Rounded off the x/y position of the popUp
      QE notes: Add test for PopUpAnchor centered where popup dimensions are odd numbers
      Doc notes: none
      Bugs: SDK-25764, SDK-25765, SDK-25432, SDK-25132
      Reviewer: Kevin
      Tests run: checkintests, ComboBox, DropDownList, PopUpAnchor
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ComboBox.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DropDownCont roller.as
