2 Replies Latest reply on Apr 17, 2010 7:47 AM by Steve Grisetti
    a/v sync issue
    frogchicken
      OK...thanks to Hunt, I've solved (temporarily) my burning DVD issue...now, I've got an editing
      question.
      I am trying to assemble a DVD of downloaded (LEGALLY!) clips.  I am downloading .mpg files, than play just fine in WMP, but when I import them to Premiere, the audio/video are out of sync...almost as if the audio is longer than the video.  I have other clips from the same source that are just fine, but 2 of them just won't play along.  Any ideas?
        • 1. Re: a/v sync issue
          the_wine_snob Level 9
          All Adobe Video programs have issues with muxed MPEG files, especially with MPEG Audio. Other NLE's experience the same issue.
          My first choice would be to convert to DV-AVI Type II's, and you should not have the OOS issues.
          Next, I'd rip the Audio from those muxed MPEG files, and Import that PCM/WAV 48KHz 16-bit file into PrE, replacing the muxed MPEG Audio.
          Last, if neither did it the trick, this ARTICLE might prove useful.
          • 2. Re: a/v sync issue
            I agree with Hunt. This sometimes happens when MPEGs are used as source video.
            Convert your downloaded video to DV-AVIs and use the DV project setting in Premiere Elements and all will be well.
            Here are some programs that will convert for you. Super is always a good place to start.
            http://forums.adobe.com/thread/415317?tstart=0
