0 Replies Latest reply on Apr 16, 2010 4:14 PM by Chet Haase
    [svn:fx-trunk] 15526: Two effects fixes, one states/SetProperty fix.
    Chet Haase Level 3
      Revision: 15526
      Revision: 15526
      Author:   chaase@adobe.com
      Date:     2010-04-16 16:14:38 -0700 (Fri, 16 Apr 2010)
      Log Message:
      The Fade fix allows objects which don't exist in the next state, but which don't have valid values set in that state for position/orientation, to fade out in place.
      The states fix cleans up the layout constraint docs in UIComponent and fixes logic in SetProperty that makes it possible to actually unset these properties in MXML.
      The AnimateTransform fix cleans up logic when using AnimateTransform directly to auto-animate properties that change between states.
      QE notes: Fade_accessor Fade_relevantProperties_Default fails because the affectedProperties of Fade has changed with one of these fixes. The test needs to be updated.
      Doc notes: None
      Bugs: sdk-25389, sdk-24989, sdk-24925
      Reviewer: Corey (UIComponent, SetProperty) and Jason (the rest)
      Tests run: checkintests, Mustella spark/effects, mx/states
      Is noteworthy for integration: yes: downstream tools wanted fix for sdk-24925
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-25389
          http://bugs.adobe.com/jira/browse/sdk-24989
          http://bugs.adobe.com/jira/browse/sdk-24925
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetProperty.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Fade.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Resize.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/FadeInstance.as
