2 Replies Latest reply on Apr 17, 2010 4:29 AM by armandix
    Help me with this quiz
    armandix
      I am developing a quiz game, He will get the questions to an xml, I would create a random, but this have  to select different answers without repeat.
      I need make a code  to tell me how many nodes have xml, and after I select a node at random and return me, but then this never happens again.
      someone help me?
        • 1. Re: Help me with this quiz
          Harry Kunz Level 4
          You can get the number of nodes nNodes like this:
          var nNodes:Number;
          var cXmlData:XML = new XML();
          cXmlData.ignoreWhite = true;
          cXmlData.onLoad = function() {
              if (fLoadSuccess) {
                  if (cXmlData.status == 0) {
                      var cNode:XMLNode = cXmlData.firstChild;
                      nNodes = cNode.childNodes.length;
          cXmlData.load("your xml file path");
          Then you can get the question from the xml after load completion:
          var nQuestion:Number = Math.random()*nNodes
          var sQuestion:String = cXmlData.firstChild.childNodes[nQuestion].firstChild.nodeValue;
          Then store the value nQuestion and use it for future checks that it already was used.
          • 2. Re: Help me with this quiz
            armandix Level 1
            Harry tanks for your help,
            but still unable to resolve, soo in my first frame i have this code
            function onQuizData(success)
                var quizNode = this.firstChild;
                var quizTitleNode = quizNode.firstChild;
                title = quizTitleNode.firstChild.nodeValue;
                var i = 0;// o numero complexo i=0
                var itemsNode = quizNode.childNodes[1];
                while (itemsNode.childNodes[i])
                    var itemNode = itemsNode.childNodes[i];
                    var questionNode = itemNode.childNodes[0];
                    quizItems[i] = new QuizItem(questionNode.firstChild.nodeValue);
                    var a = 1;
                    var answerNode = itemNode.childNodes[a++];
                    while (answerNode)
                        var isCorrectAnswer = false;
                        if (answerNode.attributes.correct == "y")
                            isCorrectAnswer = true;
                        } // end if
                        quizItems[i].addAnswer(answerNode.firstChild.nodeValue, isCorrectAnswer);
                    } // end while
                    ++i;
                } // end while
                gotoAndPlay(_currentframe + 1);
            } // End of the function
            var quizItems = new Array();
            var myData = new XML();
            myData.ignoreWhite = true;
            myData.onLoad = onQuizData;
            myData.load("questionario/questionario.xml");
            stop ();
            -- 2º frame--
            this frame contain the variable to the frame where I have the quiz
            var valores = quizItems.length;
            var currentQuestionNumber = 1;
            var numOfQuestionsAnsweredCorrectly = 0;
            var numOfQuestionsAnsweredIncorrectly = 0;
            var d1 = 1;
            trace(valores);
            --3ºframe--
            this is the frame where i wont select the aleatory response without repeat
            if (numeracao < quizItems.length)
            var array:Array = new Array(quizItems.length);
            currentQuestionNumber = Math.round(Math.random() * valores);
            else if (numeracao > quizItems.length){
            gotoAndStop(22);
            trace(currentQuestionNumber);
            var currentQuizItem = quizItems[currentQuestionNumber - 1];
            var hasAnswered = false;
            question = currentQuizItem.getQuestion();
            var i = 1;
            while (i <= currentQuizItem.getNumOfAnswers())
                _root["answer" + i] = currentQuizItem.getAnswer(i - 1);
                _root["answer" + i + "textBox"]._visible = true;
                _root["answer" + i + "Button"]._visible = true;
                _root["answer" + i + "Mark"]._visible = true;
                ++i;
            } // end while
            while (i <= 4)
                _root["answer" + i + "textBox"]._visible = false;
                _root["answer" + i + "Button"]._visible = false;
                _root["answer" + i + "Mark"]._visible = false;
                ++i;
            } // end while
            stop ();
