1 Reply Latest reply on Apr 19, 2010 6:49 AM by theEck
    Flex SOAP webservice response encoding issue
    theEck
      I'm trying to call a method to a webservice but when I pass the arguments to send the call one of the arrays isn't translated into the SOAP xml. I'm not sure how to determine if this is a bug in Flex or something in the wsdl so any help with that at least is appreciated.
      This is the object I'm passing as the operation arguments.
      (Object)#0
        date = ""
        dateFrom = "2010-04-17"
        dateGranularity = "day"
        dateTo = "2010-04-17"
        elements = (Array)#1
          [0] (Object)#2
            id = "prop5"
        locale = "en_US"
        metrics = (Array)#3
          [0] (Object)#4
            id = "pageViews"
        reportSuiteID = "slp3dorlive"
      This is the SOAP body that results (both locale and elements array are missing):
      <SOAP-ENV:Body SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
          <tns:Report.QueueOvertime xmlns:tns="http://www.omniture.com/">
            <reportDescription xsi:type="tns:reportDescription">
              <reportSuiteID xsi:type="xsd:string">slp3dorlive</reportSuiteID>
              <date xsi:type="xsd:string"></date>
              <dateFrom xsi:type="xsd:string">2010-04-17</dateFrom>
              <dateTo xsi:type="xsd:string">2010-04-17</dateTo>
              <dateGranularity xsi:type="xsd:string">day</dateGranularity>
              <metrics SOAP-ENC:arrayType="tns:reportDefinitionMetric[]" xsi:type="SOAP-ENC:Array" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/">
                <item xsi:type="tns:reportDefinitionMetric">
                  <id xsi:type="xsd:string">pageViews</id>
                </item>
              </metrics>
            </reportDescription>
          </tns:Report.QueueOvertime>
      </SOAP-ENV:Body>
