4 Replies Latest reply on Apr 18, 2010 9:05 AM by A.T. Romano
    Patch 8.01
    Pumbany
      When I open up premier elements 8 the first screen says that I need to upgrade to 8.01; but then when I click on help and choose updates within the program it says that I have no updates; Why is this happening, do I need an update or not?
        • 1. Re: Patch 8.01
          Go to C:/PROGRAM FILES/ADOBE/PREMIERE ELEMENTS 8.0 and look at the dlls.
          If some of them (e.g., Display.dll) are dated as of 2010, you have the update.
          • 2. Re: Patch 8.01
            Pumbany Level 1
            I looked and display.dll has a date of 3/28/2010
            however most of the other .dll files have a date of 9/8/2009
            Are all dll file supoosed to have a 2010 date or only certain ones?
            • 3. Re: Patch 8.01
              As I said above, you have the patch.
              • 4. Re: Patch 8.01
                A.T. Romano Level 7
                Pumbnav
                Before Steve Grisetti comment about the correlation of changes in some of those dll dates and being able to tell if you had the 8.0.1 Update (Patch) installed, I had no ideas on that.
                So, I took a look at the files in the path that he defined.
                I definitely do have the Premiere Elements 8.0.1 Update (Patch) installed. I know because I did it. In the Program Files/Adobe/Premiere Elements 8.0, all but three of the files there had 9/8/2009 dates. The three that did not have 2009 dates were:
                Core Template.xml
                XMP Document
                Date Modified 3/11/2010 10:33 PM
                85.3 KB
                Display Drivers.dll
                Date Created 3/11/2010 11:15 PM
                79.0 KB
                Templates.xml
                XML Document
                Date Modified 3/11/2010 10:53 PM
                1.62 MB
                Later today I need to uninstall reinstall Photoshop Elements 8 and Premiere Elements 8 to get at a Photoshop Elements 8 issue. I will take a good look at the before and after 8.0.1 for Premiere Elements 8.0.
                ATR
