3 Replies Latest reply on Apr 19, 2010 7:35 AM by the_wine_snob
    Adobe Encoder Issue
    jeucu
      Has anybody had any problems with Encoder freezing up?  Sometimes mine gets stuck on Encoding and never gets started.  I have a 16 minute video w/preset mpeg2-dvd ntsc prog hq, 2 pass and I can't get it to render.  When  I select "Stop Que" it hangs up.  Any suggestions?  I'm using matrox rtx.2 card
        • 1. Re: Adobe Encoder Issue
          the_wine_snob Level 9
          Can you try without the Matrox?
          Also, more info on your system will be appreciated. This ARTICLE will give you some tips on what info will be useful.
          • 2. Re: Adobe Encoder Issue
            jeucu Level 1
            Hi Bill
            Thanks for the response but I think I found the problem.  The project that I
            was working on had about 40 jpgs and I remember reading that jpgs don't do
            well w/CS4.  I changed jpgs to psds and the encoder worked okay.  I
            appreciate your response.
            Joe Euculano
            PTM Video
            joe@ptmvideo.com
            www.ptmvideo.com
            (302)598-3987
            • 3. Re: Adobe Encoder Issue
              Joe,
              Good news! I do not use JPEG's, but that has more to do with the JPEG compression. As I normally am working from RAW material to start, it's easy to keep things in a PSD workflow, and not bring JPEG's into the mix.
              I also Scale, in PS, my images to match my Project Frame Size, rather than let PrPro do the Scaling. I like the Scaling algorithms better in PS and they offer more control.
              As for PrPro and JPEG's, I have not encountered an issue. I inherited a Project with 2000+ JPEG's, and they work fine on 19 Sequences in an 8 hour opus. They ARE sized to the Project Frame Size, but there are a lot of them, and nearly each one is animated with Motion>Scale (Zoom), and Motion>Position (Pan), so it is not a simple Project.
              Best news though, is that the PSD's are working fine for you.
