3 Replies Latest reply: Apr 20, 2010 2:02 AM by Mylenium RSS
    Mask works in AE but not Premiere Pro
    R-Cole Community Member
      I have a comp in AE CS4 of a graph and I have added masks to highlight certain sections at different times. When I play it in AE it works fine but when I import the comp into premiere it does not show the masks. I also exported the comp as an avi but still no masks. What am I missing?
      Thanks in advance for any input.
      Cole
        • 1. Re: Mask works in AE but not Premiere Pro
          Mylenium CommunityMVP
          Please be more specific. Sounds like you are not correctly handling Alpha channels/ transparencies or use blending modes that require the footage to be properly part of the AE comp, not just the Premiere sequence.
          Mylenium
          • 2. Re: Mask works in AE but not Premiere Pro
            Thanks for the reply, allow me to elaborate on the composition.
            I have a jpeg of a graph on my time line. Using the rectangle mask tool I have highlighted a section of the graph using the add selection so that the rectangle is the only thing showing. I did this a total of 4 times on the same image using the opacity levels to reveal them when needed. Under the 1st JPEG I placed the same image with no masks and lowered the opacity so the rest of the graph doesn't vanish entirely, just enough to accent the section I want.
            When I play it in AE it does exactly what I need it to. The graph fades in and out except for the masks. But when I import the comp into Premiere it doesn’t show the top layer JPEG so I just see the semi transparent graph that is the bottom layer in the AE comp. I did this once before with video layers and it worked, I just don't know what I missed this time. Do the mask layers need to be on a solid layer and not the JPEG image?
            • 3. Re: Mask works in AE but not Premiere Pro
              Mmh, from your description this should work. Anything like layer styles or specific effects involved that may affect transparencies/ Alpha and are not available via Premiere? Do you do any extra processing on the linked comp in Premiere, i.e. apply a Premiere effect or change the transparency options?
              Mylenium
