4 Replies Latest reply on Apr 19, 2010 10:14 AM by The Bruder
    Is there a way to make the spark checkbox directional?
    The Bruder Level 1
      Hi All,
      Is there a (easy) way to make the checkbox with the text on the left to the quare?
      Thanks in advance,
      Lior
        • 1. Re: Is there a way to make the spark checkbox directional?
          David_F57 Level 5
          hi,
          pretty straight forward - new skin(which can be reused once you have it
          the main group change from
             <s:Group verticalCenter="0" width="13" height="13">
          to
             <s:Group verticalCenter="0" width="13" height="13" right="0">
          the label change to
              <s:Label id="labelDisplay"
                       textAlign="right"
                       verticalAlign="middle"
                       maxDisplayedLines="1"
                       left="0" right="18" top="3" bottom="3" verticalCenter="2" />
          David
          • 2. Re: Is there a way to make the spark checkbox directional?
            The Bruder Level 1
            David,
            How can i make the skin change dynamically from left to right?
            i want to built a component based on the checkbox (listed below) , and change the skin according to the direction selected by the user.
            Can you please tell me what is the best way to do it?
            Lior
            ** The "DirectionalCheckbox" component
            <s:CheckBox xmlns:fx="http://ns.adobe.com/mxml/2009"
                        xmlns:mx="library://ns.adobe.com/flex/mx">
                <fx:Script>
                    <![CDATA[
                        import flashx.textLayout.formats.Direction;
                        private var _checkBoxDireciton:String = Direction.LTR;
                        [Bindable]
                        public function get checkBoxDireciton():String
                            return _checkBoxDireciton;
                        public function set checkBoxDireciton(value:String):void
                            _checkBoxDireciton = value;
                </fx:Script>
            </s:CheckBox>
            • 3. Re: Is there a way to make the spark checkbox directional?
              Shongrunden Adobe Employee
              If you are using a recent nightly build you might be able to take advantage of the new mirroring feature.
              <s:VGroup>
                  <s:CheckBox label="left" layoutDirection="rtl" />
                  <s:CheckBox label="right" />
              </s:VGroup>
              If you are using Flex 4.0.0 release then as David mentioned it's best to reskin.
              See http://butterfliesandbugs.wordpress.com/2010/03/08/support-for-right-to-left-layouts-in-fl ex-4-x-aka-mirroring/ for more information on layout mirroring.
              • 4. Re: Is there a way to make the spark checkbox directional?
                The Bruder Level 1
                I will try the new SDK.
                Thanks a lot!
