4 Replies Latest reply on Apr 23, 2010 10:20 AM by bringrags
    Applying Pixel Bender Filters to MediaElements
    kkonrad
      I want to apply a Pixel Bender Filter to an ImageElement. In general I do this like:
      var shader:Shader = new Shader(new PBFilter() as ByteArray);
      var filter:ShaderFilter = new ShaderFilter(shader);
      var image:Image = imageElement as Image;
      image.filters = [filter];
      Now ImageElement doesn't support the .filters parameter. Are there any plans for this function in a future release of OSMF? Or are there different ways to apply a Pixel Bender filter? Thanks
        • 1. Re: Applying Pixel Bender Filters to MediaElements
          bringrags Level 4
          If you're working with the MediaPlayer, then you can assign the filter to the MediaPlayer's displayObject property once the image is loaded:
          mediaPlayer.addEventListener(MediaPlayerStateChangeEvent.MEDIA_PLAYER_STATE_CHANGE, onStateChange);
          mediaPlayer.media = imageElement;
          function onStateChange(event:MediaPlayerStateChangeEvent):void
             if (event.state == MediaPlayerState.READY)
                mediaPlayer.displayObject.filters = [filter];
          If you're working with the ImageElement directly (and no MediaPlayer), then you would need to access the element's DisplayObjectTrait, which holds the DisplayObject.
          • 2. Re: Applying Pixel Bender Filters to MediaElements
            kkonrad Level 1
            Thanks again for your help Brian. This works great on Image and Video Objects now. But what should I do when I work with a SerialElement for example and I just want to apply an effect on the second image of three dynamically? I tried to access the the MediaElement through serialMedia.getChildAt(0) but what I get is a VideoElement/ImageElement Object. I need a pure Image/VideoObject (as DisplayObject) with the filters property.
            • 3. Re: Applying Pixel Bender Filters to MediaElements
              kkonrad Level 1
              I just reused the functionallity of the MedieElementEffect class from the Transition-Example I found in the Blog. In the source code I added a Filter and removed the Fade.
              • 4. Re: Applying Pixel Bender Filters to MediaElements
                bringrags Level 4
                The DisplayObject will be null until the MediaElement is actually loaded and ready to display (which, for children of a SerialElement, usually doesn't happen until just before they're played/displayed).  So you'd need to add a listener for the DisplayObjectTrait being added to the child element:
                secondChildElement.addEventListener(MediaElementEvent.TRAIT_ADD, onTraitAdd);
                function onTraitAdd(event:MediaElementEvent):void
                   if (event.traitType == MediaTraitType.DISPLAY_OBJECT)
                      var displayObjectTrait:DisplayObjectTrait = event.target.getTrait(MediaTraitType.DISPLAY_OBJECT);
                      trace(displayObjectTrait.displayObject);
