0 Replies Latest reply on Apr 19, 2010 11:05 AM by norrisoft
    swf reference Parent Flex application
    norrisoft Level 1
      Hi All,
      I am using Flex Builder 3 and Adobe Flash CS4/AS 3.0. I have a swf created using AS 3.0 that is the source for an Image in flex:
      import mx.core.Application;
        [Bindable]
        [Embed(source="common/swf/myCool.swf") ]
        public var isSource:Class;
      <mx:Image id="ico_mag_sm" source="{isSource}" />
      I want the swf to be able to access variables of the Flex applcation that loaded it. I am able top do so by doing the following in the AS of the swf:
          while (myObject.parent){
              myObject = myObject.parent;
              var topParent = myObject;
          var myApplicationVar:String =  topParent.getChildAt(0).application["commonPath"];
      I no not want to use a swfLoader in place of the Image tag.
      So, the question is, in AS 3.0, in this situation, where I do not use a swfLoader, is there an easier way to reference the parent application?
      OR, if the SWF is the source of an image, is there a way for the Flex Application to pass a String to the swf?  I don't want to use a local connection.
      Thanks!
      Steve
