2 Replies Latest reply on Apr 19, 2010 4:39 PM by TradeWind
    Why won't Premiere/Media Encoder export FLV?
    jamcclure
      I seem to be unable to export to Flash Video under any circumstances. The result is the same regardless of what type of video I try to export: I have tried SD DV and HDV (more details below). In any case, the result is the same: AME loads, I click Start Queue, and it hangs with no progress in the conversion. When I check processes I see PPProHeadless, Import* and processcoordinationserver with no CPU utilization, and no progress in the output file. I end up having to end the AME application. I am able to export other types of video (MPEG-2, AVI, etc.) without a problem.
      Here is some more detailed information:
      The source video for one case was HDV 1440x1080 60i MPEG-2, and in the other case, a 720x480 SD DV AVI. I am outputting about 60 seconds of material, so I would not expect the process to take long. I have allowed AME to run for 15 minutes uninterrupted and there is no progress. When I Stop Queue and ask it to stop the current conversion, I get a hard hang and have to use TM to end the process. I have tried this process for all of the existing Flash Video export presets- none work. There is nothing interesting in the AME log (just a start queue description, which I'm appending to the end of this message).
      AME Log:
      4/19/2010 5:26:41 PM : Queue Started
      - Source File: C:\DOCUME~1\JIMMCC~1\LOCALS~1\Temp\High Mowing_4.prproj
      - Output File: X:\Test\PP Pro Test\Studio Arts Flash Sequence.f4v
      - Preset Used: F4V - Same As Source Flash 9.0.r115 and Higher
      - Video: 720x480, Same as source [fps], Progressive
      - Audio: AAC, 128 [kbps], 44.1 kHz, Stereo
      - Bitrate: VBR, 1 Pass, Target 1.50 [Mbps], Max 2.00 [Mbps]
      4/19/2010 5:49:03 PM : Queue Started
      - Source File: C:\DOCUME~1\JIMMCC~1\LOCALS~1\Temp\PP Pro Test_3.prproj
      - Output File: X:\Test\PP Pro Test\Sequence 01.f4v
      - Video: 1440x1080, Same as source [fps], Progressive
      Software Details:
      Adobe Master Collection CS4 w/latest updates as of 4/19/2010
      System Details:
      Dell PW690/2 CPUs/2.66GHz Xeon Dual-Cores
      Windows XP SP3 up-to-date with all OS patches
      4 GB RAM
      4 10K SATA disks inside the chassis
      1 external eSATA RAID 0 array 1.5 TB dedicated to A/V files (about 50% free)
      nVidia Quadro FX 3500 dual-monitor display w/two NEC 1770VX
      M-Audio Delta AP 192
      Pioneer Blu-ray and regular DVD drives.
      Video details:
      Mainly 1080i HDV from JVC HD200 and Canon XH-A1. Some imported from FireStore, some captured via IEEE.
      Also some older SD DV footage from Canon GL-2.
