9 Replies Latest reply on Apr 20, 2010 10:23 PM by FinFlex
    var varible:*
    FinFlex Level 1
      Simple question, what does that mean? What is the type of variable?
        • 1. Re: var varible:*
          levancho Level 3
          it is untyped varialbe that means it has no type, you can asign anything to it, number, string etc etc ..
          • 2. Re: var varible:*
            Matt Le Fevre Level 4
            i imagine it's similar to the imports you see such as
            import mx.effects.easing.*;
            which acts as an ambiguous reference including everything.
            so
            var whatever:*;
            would result in a variable that hasn't been given a definitive type, and could act as anything
            • 3. Re: var varible:*
              Sebastien V. Level 3
              The import * can be usefull if you want to import every classes in a package, this does not seem ambiguous to me.
              The * used as a var or function return type, however, I wouldn't use.
              First because every AS3 class extends the Object class. So if you do not want a typed object you can use the Object class as a type.
              Then because the * type does not only allow object values, but everything (including undefined).
              BTW for first poster, an equivalent to var v:*; is var v; (with no type at all).
              • 4. Re: var varible:*
                vijay_p4u
                Did anyone try this? I guess this results in compilation error "A type identifier is expected after the ':'".
                A variable can be declared un-typed as below.
                     var varible;
                Thanks & Regards,
                Vijay
                • 5. Re: var varible:*
                  levancho Level 3
                  Var variable - is very bad practice to do that kind of declarations in as3
                  You are basically forcing backward compartability,
                  You should do var variable:*
                  Same as using dynamic events, all that is a heavy burden on avm
                  -- Sent from my Palm Pre
                       var varible;
                  Thanks & Regards,
                  Vijay
                  • 6. Re: var varible:*
                    GordonSmith Level 4
                    Declaring
                        var myvar;
                    and
                        var myvar:*;
                    are equivalent at runtime. Neither one provides the performance advantages of "strong typing" that you get when you do something like
                        var myvar:MyClass;
                    The only difference is that the compiler normally warns when you omit a type annotation, and the * prevents the warning.
                    Gordon Smith
                    Adobe Flex SDK Team
                    • 7. Re: var varible:*
                      levancho Level 3
                      That means var a:* can be undefined? I tought undefined has ben removed
                      On Apr 20, 2010 2:35 PM, GordonSmith <forums@adobe.com> wrote:
                      Declaring
                          var myvar;
                      and
                          var myvar:*;
                          var myvar:MyClass;
                      Gordon Smith
                      Adobe Flex SDK Team
                      • 8. Re: var varible:*
                        GordonSmith Level 4
                        The 'undefined' value is a legal value in AS3. But it can be stored only in untyped variables (i.e., those indicated by a * type annotation, or those lacking a type annotation). The Object type, for example, cannot store 'undefined'.
                        As an example of * and 'undefined', the return type of getStyle() is *, and it will return 'undefined' if no style value is found in the style lookup chain.
                        Gordon Smith
                        Adobe Flex SDK Team
                        • 9. Re: var varible:*
                          FinFlex Level 1
                          Thank you. This is loud and clear.
